318 Hydro Trans Fluid level check and fluid type
27 replies to this topic
#1 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted May 13, 2011 - 10:22 AM
Hello all, just got my first garden tractor, I got a JD 318 at auction.
Seems to work ok, but I think the Hydro fluid is down.
Theres a clear tube "spyglass" on the back of the axle, and I assume the oil level should show in there? Its not right now. Is that correct? and what type of fluid do I put in it?
Anyone with experience with a 318 comments would be appeciated.
My nearest JD dealer is 30mins away, so I hoping theres a standard oil I can put in it?
Thanks,
#2 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted May 13, 2011 - 10:33 AM
Yep, just use Dexron III ATF.
  • middleageddeere said thank you
#3 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted May 13, 2011 - 10:45 AM
Jethro, Welcome to the site. If it has JD. hydro fluid in it, brownish green in color, I would stay with JD hydro. If the fluid is red, I would add ATF fluid. I never mix the 2 different fluids, but that just me. Either one will work just find, when I change the hydro fluid on my own, that I'm not planning on selling, I use ATF when I change the fluid and filter. Daniel has a lot more experience with these hydro's, and if he says you can mix them, then I'm sure that it is ok....Post some pictures sometime.. Thanks for joining..
#4 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted May 13, 2011 - 10:51 AM
I didn't think of the JD oil possibly still being in there, but I have mixed them with no problems whatsoever & have a blend in my JD F935 right now, and it's been mixed for like 2 to 3 years. That said, I won't recommend mixing.
#5 mjodrey OFFLINE
Posted May 13, 2011 - 10:54 AM
jehtro,welcome to the forum,glad to have you with us.
#6 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted May 13, 2011 - 11:59 AM
So is that tub coming of the axle with the glass part in it how I check the fluid level? I can't see anything in the tube. The hydro seems to work fine, but I guessing its low.
I'll have to take a picture and post it,
thanks again for the replies, I've always wanted a "garden tractor" and not a lawn mower, but its a whole new world of maintenance with this.
#7 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted May 13, 2011 - 12:35 PM
Yes, there should be a C bracket on the right side with the line going through it. Level anywhere within the bracket is proper level.
#8 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted May 13, 2011 - 08:05 PM
IMG00387.jpg This must be it? and I'm guess my hydro is low cause its not even visible? Geez, ah I guess I had to start somewhere,
#9 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted May 13, 2011 - 08:07 PM
Heres a picture of the new purchase, Its huge compaired to my JD 185,
#10 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted May 13, 2011 - 08:13 PM
Yep, that is it and you are low but just a little. Nice tractor and welcome to the site!
#11 Alc OFFLINE
  • 6,883 Thanks
  • 7,459 posts
Posted May 13, 2011 - 08:21 PM
You might want to change the transmission fluid & filter before you top off the level unless you know how long ago it was changed ,in the 1983 operators manual they want the fluid & filter changed 2 years or 500 hours and filter only every 100 hours , Al
#12 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted May 13, 2011 - 09:40 PM
Okay, next question, where is the filter located? Is it hard to get to ?
I'm going to assume that everything has not been done.
I really want to keep this one for along time, there hard to get ahold of around here,
JK
#13 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted May 14, 2011 - 08:54 AM
The filter is on the front side of the hydro unit, near where the driveshaft from engine enters the hydro. Should be easy to change out.
#14 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted May 14, 2011 - 12:28 PM
i keep my sight tube half full (between the metal brackets ) i only use JD fluids in mine and that reminds me i need to change my fluid and filter .thats a nice lookin tractor you have . they may not be as fast as the new mowers but they are built to last a life time .
#15 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted May 15, 2011 - 09:38 PM
I don't care about speed, the neighbor has got a gt235 , which is much faster, funny thing he doesn't want to try a tug o war with the old 318.
