Trailer control now in, what think?
8 replies to this topic
#1 glgrumpy ONLINE
  • 8,609 Thanks
  • 7,920 posts
Posted June 07, 2016 - 04:50 PM
Have new GM truck, no trailer control (bad mistake). Tried to put in the stock switch in dash, but is non-functional, dealers say can not be put in "after the fact" once built. So, got aftermarket. I chose to put it on a small compartment down low on dash so out of way of legs. Old truck had right at right knee, I missed it, but Wife hit it while driving. This one is more centered, but still about as reachable as the old one was and think will be fine. Here's couple pix.
Edited by glgrumpy, June 07, 2016 - 04:51 PM.
  • hamman, KennyP, jpackard56 and 4 others have said thanks
#2 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted June 07, 2016 - 05:20 PM
Looks good . Should be out of the way there for sure. Looks like a nice truck. We bought our truck in 2004 and it came with a controller pigtail and all. Had to mount it below dash on left. I still hit it with my leg or knee.        Roger
#3 dropped82 ONLINE
dropped82
    Nut Case
  • 2,499 Thanks
  • 1,818 posts
Posted June 07, 2016 - 06:04 PM
Looks nice. I got the factory trailer controller on my 2500 hd. I wouldn't see why you couldn't install it after the fact. Although mine does actually show the adjustments and settings on the digital display in the dash. Would probably need to go as far as swapping the ECU. Yours looks great.
Eric
Sent from my SPH-L720T using Tapatalk
  • hamman and toppop52 have said thanks
#4 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,130 posts
Posted June 07, 2016 - 08:27 PM
Looks good.
Noel
  • hamman said thank you
#5 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted June 07, 2016 - 08:54 PM
One word of advice, make it easy on the guy that has to work on it. Look for the ALDL connector for the scan tool and don't hide it with the controller. You wouldn't believe how many times that happens and you have to take the controller down to get the scanner hooked up.
  • ducky and hamman have said thanks
#6 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 08, 2016 - 04:02 AM
     All my life I have had older trucks with the brake controllers that needed to be leveled, the 04 gmc I got last year I bought  plug and play unit that needs no leveling and boy !!!!! what a difference that makes.  Looks good in there.
        Pete
  • hamman and jpackard56 have said thanks
#7 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted June 08, 2016 - 05:30 AM
Looks good  :thumbs:  I really hate the knee bashers...
#8 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted June 09, 2016 - 08:56 AM
Eric
Actually, you can install factory unit, if your service guy knows how to use his tech tool, he can go in and allow the function. Everything in that truck runs through the data buss terminal, and any factory operation can be turned on.
Having said that, yours looks great and no need to worry now.
Edited by toppop52, June 09, 2016 - 08:57 AM.
#9 Sawdust ONLINE
Sawdust
  • 5,657 Thanks
  • 3,370 posts
Posted June 09, 2016 - 09:24 AM
That's a convenient place, hate the ones above your knee. Now we need a pic of your new truck.
