Briggs Part Or Clinton Part?
6 replies to this topic
#1 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted June 06, 2016 - 07:37 PM
I am not able to find this part on any IPL ,I do not think it is a gas line maybe a oil pump line?
#2 boyscout862 ONLINE
  • 12,550 Thanks
  • 9,044 posts
Posted June 06, 2016 - 08:05 PM
Looks like generic copper line with flared ends and compression nuts. Just make it up. Good Luck, Rick
#3 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted June 06, 2016 - 08:58 PM
Do not see why some one would make a generic bend in a line?
#4 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 06, 2016 - 09:34 PM
ive seen a fuel line like that on an early briggs, but don't recall what model right now, I always thought someone just had to much time on their hands.
  • drbish and boyscout862 have said thanks
#5 chieffan ONLINE
  • 9,599 Thanks
  • 6,425 posts
Posted June 07, 2016 - 07:34 AM
Most of the older Farmall Tractors such as the H, M, hundred series, etc. had a circle bend in the fuel line that ran from the tank to the carb.  This line was about 2 ft. long and the circle bend needed to be there to provide slack in the line to install it.  The circle bend was about 2" diameter.  A lot of other farm tractors and equipment had lines like this.  This was prior to the good rubber fuel lines.
  • drbish, Lauber1 and Bmerf have said thanks
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 07, 2016 - 04:23 PM
the engine I saw this on, had the fuel bowl screwed right into the carb and that line went up to the tank. the circle is there to keep the line from breaking during vibration.
  • drbish said thank you
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 25, 2016 - 08:06 AM
Yup
