White Outdoors LT1650 not charging battery.
lt1650 help battery electric
10 replies to this topic
#1 Mennitti OFFLINE
Mennitti
  • 2 Thanks
  • 10 posts
Posted June 06, 2016 - 06:33 PM
We had a mower donated for our baseball fields.  The owner said it will not charge the battery.  We also found that after charging the battery it will drain and not start the next day once we charged it.  He claims he tore the engine apart and the engine is putting out voltage. We replaced the battery and the ignition switch this week on his advice.  Any ideas on what part needs replaced?  (Under the battery tray where the green wire connects to a mechanical assembly there is a yellow/white wire beside it not connected to anything.)
Here is the schematic.  Thanks.
http://www.partstree...ctrical-system/
  • hamman said thank you
#2 boyscout862 ONLINE
  • 12,834 Thanks
  • 9,160 posts
Posted June 06, 2016 - 06:55 PM
Welcome to GTT. If the battery dies overnight, I would suspect that you have a short circuit. The most common place for this is in the voltage regulator. Go to our Manuals Section and find the correct manual for you tractor and see if it has a troubleshooting guide. The engine manual may have it too. What engine does it have? Have you taken the battery out, charged it, and tested it, the next day? Good Luck, Rick
Edited by boyscout862, June 06, 2016 - 06:57 PM.
#3 Mennitti OFFLINE
Mennitti
  • 2 Thanks
  • 10 posts
Posted June 06, 2016 - 07:11 PM
16.5hp Briggs and Stratton 42a707.
We replaced the battery Thursday.  I fully charged it last night, today it had to be recharged to start the engine.
#4 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted June 06, 2016 - 07:32 PM
I would suggest a short circut also. As boyscout said check the voltage regulator  or the solenoid. Good Luck. Welcome to the forum.                               Roger
#5 jms180 ONLINE
jms180
  • 1,511 Thanks
  • 1,564 posts
Posted June 06, 2016 - 08:12 PM
disconnect the voltage regulator and see if the battery will stay charged if so start checking at voltage regulator and stator coil.
#6 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted June 06, 2016 - 10:00 PM
B&S 42a707 should have a Diode on the red charge wire coming out from under the flywheel.If that Diode is bad is will allow voltage back into the Stator even with the key Off.Some times it burns up the stator when the diode goes out.
Pull the flywheel and have a look at your Stator.If you see any discoloring on the coils on the stator than it's more than likely burnt up.Coils on the stator should be a nice copper color.
Would not worry about the Yellow wires.More than likely the one that's hanging loose goes to the seat safety switch.
Here's a used but tested stator for sale cheap.
http://www.ebay.com/...ZAAAOSw9~RXI9tT
Edited by EricFromPa, June 06, 2016 - 10:02 PM.
  • Mennitti said thank you
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 07, 2016 - 10:29 AM
With the key off insert a current meter into the + lead from the battery. If you read a current then you have a short somewhere. You can then start disconnecting loads until you find the short. The series diode is a good candidate.
#8 Mennitti OFFLINE
Mennitti
  • 2 Thanks
  • 10 posts
Posted June 07, 2016 - 04:00 PM
The shop where this was originally purchased also told me diode was likely the problem.  What do they look like?
Thanks!
#9 Mennitti OFFLINE
Mennitti
  • 2 Thanks
  • 10 posts
Posted June 08, 2016 - 04:12 PM
If the diode is the bulge to the right of the white plug, I am getting ground on both sides using a test light.
#10 Mennitti OFFLINE
Mennitti
  • 2 Thanks
  • 10 posts
Posted June 08, 2016 - 04:16 PM
1
#11 jms180 ONLINE
jms180
  • 1,511 Thanks
  • 1,564 posts
Posted June 09, 2016 - 04:57 PM
https://www.youtube....h?v=qSDRsz5-t7I
Watch video maybe helpful
Edited by jms180, June 09, 2016 - 04:58 PM.
