How to test a Cub 1250 PTO switch
2 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted June 06, 2016 - 05:20 PM
Have a analog multi tester. What setting should I use and do I just check switch for continuity?
#2 boyscout862 ONLINE
  • 13,554 Thanks
  • 9,430 posts
Posted June 06, 2016 - 07:07 PM
Rather than risk a multi tester, I would just use a test light that is grounded and start at the positive terminal of the battery. Test at the in terminal of the switch to make sure juice is getting to the switch. Test at the out terminal with it off and then on to make sure it is working right. If there are problems, make repairs as you go. Test at the in terminal of the PTO. If it is okay, then you need to check the voltage to besure that a full 12 volts is getting to the clutch. MAke sure the clutch is well grounded. If it still doesn't work, the clutch may be bad. Find the manual for it in our Manuals Section and follow the testing proceedures. Ask questions here when you've got them. Pics can help alot. Good Luck, Rick
  • CRFarnsworth and Sawdust have said thanks
#3 chieffan OFFLINE
  • 11,368 Thanks
  • 7,116 posts
Posted June 12, 2016 - 10:27 AM
On mine the seat switch in in that circuit also.  Clutch won't stay on if the seat wire is unplugged or the switch is bad.  Ask me how I know !
  • Sawdust said thank you
