JD 265 electric clutch
5 replies to this topic
#1 Aussiej OFFLINE
Aussiej
  • 1 Thanks
  • 2 posts
Posted June 06, 2016 - 04:07 PM
G'day all the electric clutch cuts on and off while mowing any thoughts wiring seems fine visually and it will stay off for a while the come back on any help please I'm at a lose
#2 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted June 06, 2016 - 04:23 PM
If the wiring is good, the switch may be the culprit!
  • WNYTractorTinkerer and Aussiej have said thanks
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,462 Thanks
  • 5,768 posts
Posted June 06, 2016 - 06:04 PM
Usually it is the switch..  How many hours?  Is the machine stored outside?  Might just be as simple as a dirty contact..  R & R the switch plug and check / clean the contacts..
#4 Aussiej OFFLINE
Aussiej
  • 1 Thanks
  • 2 posts
Posted June 06, 2016 - 08:29 PM
Thanks men , cleaning all contacts tomorrow ,
It's stored in the barn and cleaned after every use , but dust is dust
#5 DennyIN OFFLINE
DennyIN
  • 343 Thanks
  • 207 posts
Posted June 07, 2016 - 08:46 AM
Along with the prior mentioned recommendations, you might also want to check the clutch gap with a feeler gauge. Older clutches had a slot so you could enter a feeler gauge, some newer ones I've seen don't have that feature. I don't have the gap spec handy but may be in the .012 - .016 inch range, but you should verify first.
#6 lrhredjb ONLINE
lrhredjb
  • 698 Thanks
  • 570 posts
Posted June 17, 2016 - 07:47 AM
My neighbor has the same problem going on with his JD 111 or 112. Blade clutch cycles on and off. There are quite a few wires going to that clutch dash switch. Hope you fix yours soon and tell us what the problem was.
