Question for the lefty's
39 replies to this topic
#1 HDWildBill OFFLINE
  • 8,978 Thanks
Posted June 06, 2016 - 09:11 AM
This past weekend my son and I got into a discussion about him being a lefty.  He has always wanted to do mechanical things but has always struggled with the "righty tighty lefty loosey"  thing and really anything that rotates his "Natural" is always backwards.
I have really never understood this until a couple of weeks ago when we were changing the tires on his bike. The clamp on the tire changer (that holds the rim tight) clamps down contrary to the way I think it should go so I'm always turning it the wrong way.  Well he never had a bit of a problem with that clamp.  I have always just thought that being left handed just meant that your left hand was to dominate one but that was it.  Now I'm curious to see if there is more of a difference being left handed then I had thought.  This leads me to ask those of you who are left handed do you have problems working on equipment keeping things straight in you mind?  Thanks
  • hamman, Lmiller3358, MFDAC and 3 others have said thanks
#2 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted June 06, 2016 - 10:03 AM
No problem here.
We run into a left-hand thread about .00000001% of the time and that is enough to throw anyone off.
Garry
  • hamman, Lmiller3358, HDWildBill and 1 other said thanks
#3 Austin OFFLINE
Austin
  • 668 Thanks
  • 662 posts
Posted June 06, 2016 - 10:27 AM
I'm a lefty. I have issues with screws and bolts. They never screw in right.
  • hamman, Lmiller3358 and HDWildBill have said thanks
#4 Traill95 OFFLINE
Traill95
    Traill95
  • 1,852 Thanks
  • 1,017 posts
Posted June 06, 2016 - 10:38 AM
I was a Lefty but when I was in school they made us all learn to write right handed and now I use the right hand for everything except sports. I have never had any trouble  mechanically, though that might be from having to learn to  write right handed.
#5 olds45512 OFFLINE
olds45512
  • 1,341 Thanks
  • 677 posts
Posted June 06, 2016 - 10:58 AM
I'm a lefty but only use my left hand for writing, everything else I can do with either hand without issue.
#6 MH81 OFFLINE
Posted June 06, 2016 - 11:14 AM
Insert obligatory "Loose Screw" comment here...
#7 Leonard VanCamp ONLINE
Leonard VanCamp
  • 635 Thanks
  • 457 posts
Posted June 06, 2016 - 11:19 AM
I'm also a lefty and the same goes for me. The only thing I find annoying is most firearms are right handed, but I've been able to adapt.
Edited by Leonard VanCamp, June 06, 2016 - 11:21 AM.
  • hamman, Lmiller3358, HDWildBill and 3 others have said thanks
#8 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted June 06, 2016 - 11:33 AM
I'm a righty and still have problems working on equipment and keeping things straight in my mind.  What's that mean?
  • Gtractor, MH81, hamman and 2 others have said thanks
#9 EricR OFFLINE
EricR
  • 709 Thanks
  • 427 posts
Posted June 06, 2016 - 11:34 AM
I'M a lefty also but write right handed, but no problems here. And you know what they say us left handers are in our right mind lol.
#10 olds45512 OFFLINE
olds45512
  • 1,341 Thanks
  • 677 posts
Posted June 06, 2016 - 11:37 AM
I shoot right handed also so never been an issue.
  • hamman and Lmiller3358 have said thanks
#11 classic ONLINE
classic
  • 5,570 Thanks
  • 2,324 posts
Posted June 06, 2016 - 12:56 PM
I could never find left handed sports equipment except for a baseball glove and golf clubs. I always wanted to play tennis, swing a bat, bowl, etc., but I'll have to wait for left handed sports equipment to catch on.
  • IamSherwood, Lmiller3358 and HDWildBill have said thanks
#12 bbuckler ONLINE
bbuckler
  • 3,660 Thanks
  • 3,190 posts
Posted June 06, 2016 - 01:03 PM
I'm lefty and have no problem (expect my writing at least I can read it lol)
  • Leonard VanCamp said thank you
#13 HDWildBill OFFLINE
  • 8,978 Thanks
Posted June 06, 2016 - 01:05 PM
I believe I'm starting to see a pattern forming.  It seems if some learned to do a dominate task with their right hand it seems to have either resolved any issue or eased it.  We never pushed Mike to use his right hand.  Might be interesting to see what others have to say as well.
bbuckler: I'm right handed and I can't read my writing so your a step above! :D
  • bbuckler said thank you
#14 Bud OFFLINE
Bud
  • 399 Thanks
  • 415 posts
Posted June 06, 2016 - 01:51 PM
There is a lot of difference in doing something left handed or right handed. One pushes the pencil with the left hand and pulls the pencil with the right hand, which would be like writing back words. It would be like a right handed person writing on the paper starting on the right side of the paper and going left. So who's reading backwords and who's reading forewords? One also ties a shoelace differently. Left or right the bow will lay parallel or perpendicular to the shoe depending if you tuck over or under with the loop. Ok I have to get back to work, have fun.
  • Gtractor, Alc, HDWildBill and 1 other said thanks
#15 JBRamsey OFFLINE
JBRamsey
  • 1,541 Thanks
  • 869 posts
Posted June 06, 2016 - 02:19 PM
Take both hands and move your thumb and fingers like you are running in a nut or bolt. One turns right and the other left........ Now think about if you always naturally go to your left hand. I'm not a lefty, but I would think after doing something enough times you would get used to it.
  • HDWildBill said thank you
