Hard to get fluid into the tranny!
5 replies to this topic
#1 KC9KAS OFFLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
Posted June 03, 2016 - 07:27 PM
All documentation I have seen says that our 1970 GILSON S 14 automatic holds 4 quarts of ATF.
This evening, we drained it, replaced the filter and started to refill the transmission.
We only got approximately 2 quarts out of the transmission and that was by tilting the tractor at about 45*.
We have worked over an hour and only have 2 quarts back in the tranny, and we have it tilted at a 45* angle the opposite direction.
Has anyone else experienced the same problems?
I know the manual says to take it to a "factory service" department, but that ain't gonna happen!
  • propane1 said thank you
#2 propane1 OFFLINE
propane1
  • 9,468 Thanks
  • 4,395 posts
Posted June 03, 2016 - 07:54 PM
Air breather pluged.
Noel
#3 John Arsenault OFFLINE
John Arsenault
  • 2,925 Thanks
  • 1,324 posts
Posted June 03, 2016 - 08:08 PM
May have to pump it in there like I do my volvo transmission. Many types of pumps you can get a boat primer ball may work.  I have used the little plastic hand pumps and they are good for a few uses.
#4 DougT OFFLINE
DougT
    Dog Approved
  • 7,116 Thanks
  • 5,079 posts
Posted June 03, 2016 - 08:12 PM
Does it have a dipstick or full level plug? I'd fill it to that and not worry about the book. It wouldn't be the first time I've seen one wrong. Maybe it's supposed to be 4 pints?. You might want to start it and make sure the filter is full.
#5 KC9KAS OFFLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
Posted June 04, 2016 - 07:20 AM
It has a 3/4" pipe "TEE" and you take the plug out to drain & refill.
We drained 2 quarts, and I have 2 quarts back in. I will run it a little to fill the filter then check it and top it off.
#6 Speedy903 OFFLINE
Speedy903
  • 1 posts
Posted December 17, 2017 - 03:48 AM
My Gilson Hydro 15 has a similar problem. It's full to the 'T' plug when slanted to left but works only on level ground. If the ground slants to the left or up grade or when you lift the deck it just runs & doen't move. Acts like a GM car when 1 qt. LOW ON FLUID (it doesn't want to back up) This hydro is built like it's for a D-8 dozer compared to my John Deere 322. It just doesn't want to work (go). The 15hp Briggs runs like a top & I have all the attachments for it.
HELP Speedy
