Spark plug question.
9 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 1,502 Thanks
  • 1,653 posts
Posted June 03, 2016 - 01:34 PM
Does anyone have a good breakdown of what spark plugs have removable tops and threaded studs underneath like those used on old Briggs and Stratton engines, as well as the thread size?  Looking for the tread size for the top on a J8c, as I would like to order some nuts for on my old Briggs and Strattons.
  • propane1 and sallyih16 have said thanks
#2 boyscout862 ONLINE
  • 10,040 Thanks
  • 7,670 posts
Posted June 03, 2016 - 03:39 PM
I used to just steal them from old plugs because the new ones would sometimes not have them. The tops were loose and the plastic wraps of the plug packages often leaked. Good Luck, Rick
  • propane1 said thank you
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 8,544 Thanks
  • 4,774 posts
Posted June 03, 2016 - 04:05 PM
Either 6-32 or 4-40..  Been a while since I saw one..
#4 DougT ONLINE
DougT
    Dog Approved
  • 5,928 Thanks
  • 4,386 posts
Posted June 03, 2016 - 06:18 PM
I know I've seen them with different sizes. One nut won't fit the same plug. that's where a good thread guage comes in handy.
  • ducky and propane1 have said thanks
#5 adamjd200 OFFLINE
adamjd200
  • 1,502 Thanks
  • 1,653 posts
Posted June 03, 2016 - 09:59 PM
That may be why most nuts I have seen for this application seem to be made to fit a little loose,
#6 JBRamsey ONLINE
JBRamsey
  • 1,084 Thanks
  • 641 posts
Posted June 04, 2016 - 09:01 PM
Take the old plug to the hardware store and see what fits.
#7 KennyP OFFLINE
  • 29,485 Thanks
  • 40,455 posts
Posted June 05, 2016 - 06:48 AM
If I had one laying about, I could probably figure it out. Probably a 6.
#8 adamjd200 OFFLINE
adamjd200
  • 1,502 Thanks
  • 1,653 posts
Posted June 05, 2016 - 10:20 AM
That would work, except everyone around here only sells this small stuff In packs of 20+, no one sells anything under 1/4" loose, I could dig through my personal stash, the nuts I plan to order are brass thumb nuts.
#9 FixItCharlie OFFLINE
FixItCharlie
  • 393 Thanks
  • 268 posts
Posted June 05, 2016 - 12:31 PM
Some wire strippers also have the ability to cut small screws. I have used these to find the size & thread for small threaded items.
Charlie
#10 adamjd200 OFFLINE
adamjd200
  • 1,502 Thanks
  • 1,653 posts
Posted June 07, 2016 - 02:21 PM
Figured it out, J8c is 8-32 for the top, just so happened to find a pack of 8-32 hex nuts while looking for something and tried them on a whim.
  • DougT said thank you
