new guy with a couple question.
11 replies to this topic
#1 KY hillbilly OFFLINE
KY hillbilly
  • 46 Thanks
  • 66 posts
Posted June 03, 2016 - 12:16 PM
Hello all new guy here iv got a couple david bradleys, and just got a motgomery wards model L. My qustions are what engines are correct for a david bradleys I think mine is a model 817? Also what kind and size pulley is supposed to be on the engine of that Mw L. Thanks for advance for the help.
Edited by KY hillbilly, June 03, 2016 - 02:21 PM.
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 03, 2016 - 12:51 PM
:welcometogttalk: :wewantpics:
#3 GWest OFFLINE
GWest
  • 557 Thanks
  • 509 posts
Posted June 03, 2016 - 01:00 PM
A bit of info here
https://www.partstre...walking-tractor
The D-A13 pulley replaced by 8021013 was also used on the Simplicity model D.
3/4" shaft and 3 grooves 2-13/16" and 2-1/4" OD but don't know how many for what size.
Garry
  • Lauber1 said thank you
#4 KY hillbilly OFFLINE
KY hillbilly
  • 46 Thanks
  • 66 posts
Posted June 03, 2016 - 01:12 PM
This is my db I don't have a pic of the Mw yet. 20160214_114141_zpssmwajpcz.jpg
  • Gtractor, LPBolens, Alc and 5 others have said thanks
#5 oldedeeres OFFLINE
oldedeeres
  • 10,492 Thanks
  • 5,096 posts
Posted June 03, 2016 - 04:55 PM
:welcome:       Great snow pic,   welcome aboard.
#6 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted June 03, 2016 - 07:14 PM
:welcometogttalk:
#7 GWest OFFLINE
GWest
  • 557 Thanks
  • 509 posts
Posted June 04, 2016 - 09:45 AM
A bit of info here
Garry
Looked at a D-model and the large 2-13/16" OD is closest to the engine with 2 grooves outboard with 2-1/4" OD.
Simplicity often turned the pulley around on the crankshaft to get a different speed for the transmission.
Garry
Adding
Each groove designed for a 1/2" wide belt.
Edited by GWest, June 04, 2016 - 05:33 PM.
#8 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 05, 2016 - 10:08 AM
we would have to have a lot more info on the DB, as the factory built 23 different models from 47 thru 67. There a tag on the left side of the gear, with a model number at the top and a series number at the bottom. Those number will tell us what model you have and maybe about when it was built. There are no factory listed for dating one all you can be is close to the yr. if the orginal engine is still in place, there a more accurate date might be from using its numbers.
#9 KY hillbilly OFFLINE
KY hillbilly
  • 46 Thanks
  • 66 posts
Posted June 05, 2016 - 10:28 PM
I was wrong it 254 model number sorry guys. 20160605_181011_001_zpsr8bvkdpx.jpg
Edited by KY hillbilly, June 05, 2016 - 10:28 PM.
#10 DougT ONLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted June 06, 2016 - 01:00 AM
Actually, the model is a 5752. The 254 is the series number. I'm sure Lauber can fill you in more
#11 KY hillbilly OFFLINE
KY hillbilly
  • 46 Thanks
  • 66 posts
Posted June 06, 2016 - 04:16 PM
Dang it a good thing I tock a picture lol!
#12 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 06, 2016 - 05:11 PM
ok that tractor was built around 1951, maybe 52 roughly, that model started in 1950, the engine would have been a Model 6 briggs, with 2hp. its used a spring clutch, instead of the ball lock ones built later on. It used a simple dual pulley with 2 1/2 on one end, & 2 1/4" on e other, with a wide space between them to run a flat belt on, in case you want to pump a little water or grind something for the chickens.  In my area 52 model tractor aren't very common, a lot more of them out east. Most common Db's here are the 51 & 560 models.
  • DougT said thank you
