Need help converting to elect start
5 replies to this topic
#1 Crazywillie1 OFFLINE
Crazywillie1
  • 1 Thanks
  • 2 posts
Posted June 02, 2016 - 04:07 PM
Hi I need help . Have a 8-25 wheel horse . Mod. 56123, need to convert to electric start . I have a10 horse Tecumsa motor and wire bundle as well as a bundle from 70040 toro elctric start . Have to change pulleys but not sure how to wire it
  • fernandofr4 said thank you
#2 Crazywillie1 OFFLINE
Crazywillie1
  • 1 Thanks
  • 2 posts
Posted June 02, 2016 - 04:10 PM
The wheel horse motor doner came from a dynamark . Both are rear engine , both motors are Tecumsa , 1 a pull star 1 electric , need to know how to wire . And any advice on changing pulleys , and getting or rebuilding carb
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 03, 2016 - 07:36 AM
:welcometogttalk: :camera:
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,881 Thanks
  • 10,048 posts
Posted June 03, 2016 - 07:58 AM
You need to get a wiring diagram and you will need to get a different ignition switch as well.
#5 Achto ONLINE
Achto
  • 295 Thanks
  • 108 posts
Posted June 28, 2016 - 02:25 PM
Another  thing to consider is that the pull start only engine may not have a charging system. If this is the case you may need to use the fly wheel and stator from the electric start engine. See if you can find an owners manual for your Wheel Horse, they include a wire diagram in most of their manuals. As for the carb, there are a lot of low priced reproductions out there for the techy engines.
#6 GWest OFFLINE
GWest
  • 553 Thanks
  • 504 posts
Posted June 29, 2016 - 04:10 AM
1989
http://www.wheelhors...l-wiring-snpdf/
1990
http://www.wheelhors...ed-492-4509pdf/
Garry
