STIHL Gas Trimmer FS76
gas tank
5 replies to this topic
#1 alrayo OFFLINE
alrayo
  • 2 posts
Posted June 01, 2016 - 09:15 AM
Hi every body, this is my first post in this forum, now happy to be part of it.
I do have a Stihl FS76 weed trimmer, and it had been seated in my garage for several months, now I need it to work my yard in a new location were I moved and found that the fuel tank it is cracked (I made a research and found that the tank actual PN: 4133 350 0400).
Also I found a Stihl distributor near to my work place and have ordered, tree weeks later, they said that it is in back order, I wondering if other fuel tank could fit on my trimmer, I found several options that I found in very popular web place, as the following parts number:
  • 4137 351 0400
  • 4137 350 0410
Can someone confirm if such available options could really fit on my trimmer?
Thanks
#2 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted June 01, 2016 - 10:08 AM
Welcome to the forum.
I have sent you a private message concerning your tank.
  • alrayo said thank you
#3 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted June 01, 2016 - 10:31 AM
Welcome to GTTalk !  Can't help you with your question but I think there's some info around on repairing plastic fuel tanks , I've never done one myself though .
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted June 01, 2016 - 11:08 AM
:welcometogttalk:
#5 alrayo OFFLINE
alrayo
  • 2 posts
Posted June 06, 2016 - 10:35 AM
Hi, I couldn't find any new tank whit such part number, so I decided to repair the cracked one with epoxy, seems that it will be a good solution for awhile.
I also decide to tear down my trimmer to clean it & lubricate what it is necessary, while cleaning the "Fan Housing" I notice that the "clutch drum" bearing do not turn as should, so I wondering if it is possible to unmount it to change for one new, have some one did such type of job?
#6 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,458 Thanks
  • 5,765 posts
Posted June 06, 2016 - 06:21 PM
They are usually threaded on the crankshaft..  loosen in the other direction from engine rotation..  Good Luck!
Also tagged with one or more of these keywords: gas tank
