Caption This! 5-31-16
12 replies to this topic
#1 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,232 Thanks
  • 6,059 posts
Posted May 30, 2016 - 11:06 PM
:poke:  :rocker2:  :bounce:  :peace:
  • Alc, Lmiller3358 and boyscout862 have said thanks
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,803 Thanks
  • 4,302 posts
Posted May 31, 2016 - 12:52 AM
GREAT!
  • Lmiller3358 said thank you
#3 Lmiller3358 OFFLINE
Lmiller3358
  • 1,544 Thanks
  • 1,456 posts
Posted May 31, 2016 - 04:16 AM
That must be for when you had  " Wicked Tuna " the night before !
  • Alc, WNYTractorTinkerer and HANKG have said thanks
#4 daytime dave OFFLINE
  • 4,963 Thanks
  • 6,596 posts
Posted May 31, 2016 - 06:02 AM
That doesn't bode well for it being very soft....................
#5 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,099 Thanks
  • 10,169 posts
Posted May 31, 2016 - 06:18 AM
Ummmhh. . . . .         This suggests there are at least two people in the stall.
#6 HANKG OFFLINE
HANKG
  • 6,589 Thanks
  • 3,526 posts
Posted May 31, 2016 - 06:30 AM
You need that after releasing the brown bass in the little pond.
  • Bruce Dorsi and toppop52 have said thanks
#7 Jack OFFLINE
Jack
  • 1,319 Thanks
  • 867 posts
Posted May 31, 2016 - 06:41 AM
For the "big one" that didn't get away.
  • HANKG said thank you
#8 olds45512 ONLINE
olds45512
  • 1,400 Thanks
  • 697 posts
Posted May 31, 2016 - 07:45 AM
Finally!! a tp dispenser you can set the drag on, that should keep it from self unwinding.
  • KennyP and HANKG have said thanks
#9 toppop52 OFFLINE
toppop52
  • 5,530 Thanks
  • 4,898 posts
Posted May 31, 2016 - 08:38 AM
Loosen the drag, let 'em run!
#10 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted May 31, 2016 - 09:07 AM
Catchin' Crappie.
  • WNYTractorTinkerer, oldedeeres and dblover have said thanks
#11 gtcsreg OFFLINE
gtcsreg
  • 2,086 Thanks
  • 2,039 posts
Posted May 31, 2016 - 09:41 AM
Soon to be available to everyone, only found at your local Bass Pro Shop!
#12 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 10,252 Thanks
  • 3,321 posts
Posted May 31, 2016 - 10:02 AM
Mounted on a wall instead of a rod
This reel is made with a little mod
Instead of line it holds paper
To function for the washroom caper
It keeps things from unwinding at an uncontrollable rate
But be extra careful if you try and use bait
The idea is good to make the TP last
But could make a mess if you tried to cast
Not to mention that when the roll is done
Loading a new one is lots of fun
So if you come across a stall with this feature
And the roll has been left bare by the last creature
Move on to another one that paper has lots
So that down with your pants you are not caught
  • oldedeeres said thank you
#13 Cvans OFFLINE
  • 7,278 Thanks
  • 6,369 posts
Posted May 31, 2016 - 10:10 AM
OSHA approved TP dispenser.
