Honda H4514H PTO Installation
3 replies to this topic
#1 Cadmandu OFFLINE
Cadmandu
  • 1 Thanks
  • 4 posts
Posted May 30, 2016 - 01:10 PM
Hi All,
I just removed my PTO and ordered a new one and a new bearing for the control plate.
Do you press the bearing on the power output shaft or in the control plate?
I read that you have to make some measurement that has something to do with the base plate bolt. A spring pulls the control plate
back against the head of a bolt that you can adjust. What and how do you measure this.
Thanks
  • fernandofr4 said thank you
#2 Cadmandu OFFLINE
Cadmandu
  • 1 Thanks
  • 4 posts
Posted May 31, 2016 - 04:43 AM
I read that i need 50/50 ethylene glycol coolant with distilled water for aluminum engines. Where do I buy that?
#3 Alc ONLINE
  • 7,348 Thanks
  • 7,633 posts
Posted May 31, 2016 - 05:10 AM
Welcome to GTTalk ! Can't help with the pto question but an auto parts store should be able to fix you up with coolant If you have your owners manual I would take it too . They my ask a question that's answered in it
  • Cadmandu said thank you
#4 RNC OFFLINE
RNC
  • 1 Thanks
  • 2 posts
Posted January 12, 2018 - 11:09 AM
I use either rainwater or water I save from the dehumidifier in my basement.
When you compare the price of the 50/50 mix you get at the store and that
of 100% anti-freeze, you're paying quite a bit for that 50% water.
RNC
