Massey ferguson 16 value and warnings
20 replies to this topic
#16 dropped82 ONLINE
dropped82
    Nut Case
  • 2,495 Thanks
  • 1,816 posts
Posted May 30, 2016 - 01:25 PM
Unloaded! That was what I was thinking maybe happened and whole rig is now bent out of shape from that! See if you can at least roll it off the trailer on level and get better look, and underneath too. $500 too much, maybe the $300 IF not twisted frame. These frames are like a 3" x 10" channel and pretty hard to straighten one of those out.
They're also pretty hard to twist. Keep that in mind. If it's twisted that bad, that's a pure parts machine. Lord only knows what else you'll find after working on it.
Eric
Sent from my SPH-L720T using Tapatalk
  • Greasy6020 said thank you
#17 dualresponse1731 OFFLINE
dualresponse1731
  • 255 Thanks
  • 175 posts
Posted May 30, 2016 - 02:07 PM
Is the right rear tire flat? or in a hole in the trailer?
#18 Greasy6020 OFFLINE
Greasy6020
  • 1,473 Thanks
  • 1,397 posts
Posted May 30, 2016 - 02:31 PM
Dunno... I'd have to look at the machine again..
#19 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted May 30, 2016 - 05:41 PM
Does it run?
Does it drive?
I see a early style snow blower, mower deck, dozer blade that appear to be for that MF12 tractor.
You will need all the brackets to mount them.
The foot pedal PTO has be modified, want to make sure that works or else the mower and snow blower won't work.
It has Massey 2pc wheel weights, does it have the rear lift with sleeve hitch?
If it runs and drives and comes with all the attachment brackets, then it's worth the $$$.
If it doesn't run or drive then too much $$$
IMO that is a parts tractor with some attachment's.
#20 limebuzz ONLINE
limebuzz
  • 996 Thanks
  • 976 posts
Posted May 30, 2016 - 08:50 PM
It has to be a 12 hydro.if it runs and is not bent up,i say it's worth the $450-500.IMO. Good luck
#21 Greasy6020 OFFLINE
Greasy6020
  • 1,473 Thanks
  • 1,397 posts
Posted May 30, 2016 - 09:25 PM
I don't know ANYTHING about the tractor other than, it has a snow blower, a mower deck (that doesn't look right for the massey ferguson) and a dozer blade...
The guy said he had it running last year. It has a 16 hp kohler magnum, a hydro transmission...
No pics of anything else except what I shared with you guys...
