Where can you get these? (rear reflector lights)
4 replies to this topic
#1 dualresponse1731 OFFLINE
dualresponse1731
  • 254 Thanks
  • 175 posts
Posted May 28, 2016 - 05:28 PM
In an ongoing quest to redo my LGT, I found this pic of the LGT rear reflectors/lights. Can you even still get these, or is there a better LED replacement that someone has discovered? I did a search but couldn't find anything.
Thanks,
Ron
Edited by dualresponse1731, May 28, 2016 - 05:29 PM.
  • Sawdust said thank you
#2 boyscout862 ONLINE
  • 12,551 Thanks
  • 9,044 posts
Posted May 28, 2016 - 05:34 PM
They look similar to ones that Walmart sells in their trailer hardware section. Good Luck, Rick
Edited by boyscout862, May 28, 2016 - 06:01 PM.
  • dualresponse1731 said thank you
#3 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted May 28, 2016 - 10:36 PM
If that's a 2"x 4" light fixture O'REILLY's has them for a few bucks. Check their website to see if their in stock in your area if not you have to order online.
#4 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted May 29, 2016 - 06:44 AM
Hey that pic looks very familiar!! Good luck with them, it took an act of god to get them!! Ihad to buy $50 worth of them to get them from Tennant in the Carolinas.
Edited by skyrydr2, May 29, 2016 - 06:46 AM.
#5 dualresponse1731 OFFLINE
dualresponse1731
  • 254 Thanks
  • 175 posts
Posted May 29, 2016 - 10:29 AM
Ha! I bet you recognize where I stole it from  :D  :D  :D ...I am assuming they are all gone now!
You would think it would be easy to just order a rectangular reflector, but the hole is 1.5 inches, and most of the cheap reflectors are 1 3/8 inches high, so they don't work. I orderded a pair that are "supposed" to be 1 1/2 inches, but we will see... I might then mount an LED behind the hole so it will be lit. Who knows....
