Need help verifying this speedex
6 replies to this topic
#1 Supermrj5 OFFLINE
Supermrj5
  • 1 posts
Posted May 28, 2016 - 01:55 PM
Model number 24–434 type number is 013201 code number is 651-1291 my dad recently purchased this and we are looking to find out if it is in fact a S 24 model
#2 MiCarl ONLINE
MiCarl
  • 1,563 Thanks
  • 838 posts
Posted May 30, 2016 - 06:51 PM
I'm sorry no one has been able to help you out.
I'm not up on the S models.  There is a guy that had a project to record all the Speedex SNs he could get hold of.  He had a lot of the production records going through the mid seventies.  I haven't heard anything on his project lately, but he might be able to help you out.
His web site is http://www.speedextractorarchives.com/, his contact information seems to be missing from it currently. Try contacting him at info@speedextractorarchives.com
  • jimmy G said thank you
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,179 Thanks
  • 5,775 posts
Posted July 14, 2016 - 02:52 PM
:welcometogttalk: :camera: might help with identification
#4 speedbird OFFLINE
speedbird
  • 216 Thanks
  • 123 posts
Posted August 22, 2016 - 05:26 PM
I'm assuming that those numbers are from the B&S engine. My understanding is The 24 means it is a 24 cu. in.(10 hp ). The 65 in the code tells that the engine was built in 1965. If that is the original engine it would be an S 24 probably made in 1965. The serial number should be stamped on the RHS. frame rail below the engine. It would be 3or4 numbers plus a letter. If is the letter G it would be a 1965. Hope this helps.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,179 Thanks
  • 5,775 posts
Posted September 09, 2016 - 03:36 PM
Haven't found ANY numbers on my frame rail.
#6 speedbird OFFLINE
speedbird
  • 216 Thanks
  • 123 posts
Posted September 12, 2016 - 06:58 PM
Don't feel left out. They can be hard to impossible to find.
#7 glgrumpy ONLINE
  • 7,707 Thanks
  • 7,318 posts
Posted September 27, 2016 - 06:57 AM
Some of mine are on Left Hand frame rail, AND, don't always show good until you remove some paints that maybe have been put on in past. Have seen most on outside surface, but some were on top surface was told. Is there NO decals on tractor?  Usually an S24 in a circle near front sides. Post some pix like mentioned, including the trans and rear.  Some S-24's had same round hood as smaller ones, yet some had the later Barn Shape hood, much better looking.
Edited by glgrumpy, September 27, 2016 - 06:57 AM.
