clutch disc
3 replies to this topic
#1 Nicky1 OFFLINE
Nicky1
  • 25 Thanks
  • 9 posts
Posted May 27, 2016 - 05:04 PM
   I just was wondering if anyone had made their own clutch disc [ like the Cub Cadet clutch]out of the lining material that McMaster Carr sells. They have it in all thicknesses and widths. I just don't know if it is rigid enough. I had some before that I used to reline the disc brakes on my Cub and it came in a box rolled up.
      Thanks in advance, Nicky1
  • VTXrider and Sawdust have said thanks
#2 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted May 28, 2016 - 07:53 AM
The clutch disc in my 960 is composed of friction material bonded to both sides of a steel plate. The friction material is extremely brittle and has broken in the area of the drive pins. When it comes time to replace it I'm going to use a solid aluminum disc like Brian Miller describes in his pulling pages. If you bonded the material to a steel disc it might work but keep in mind that there is very little travel in the release mechanism so make sure that it isn't too thick.
  • Alc and Sawdust have said thanks
#3 Nicky1 OFFLINE
Nicky1
  • 25 Thanks
  • 9 posts
Posted May 28, 2016 - 02:04 PM
The tractor i'm using it in is a Ford LGT 100. I'm putting a Cub type disc clutch in between the engine and the right angle drive gear box and I have some other plans for the area where the belt tightener clutch was originally. what I need is a 3" or so pulley on the clutch end of the engine---kinda like your 960 Mtd. The drive plate will be on the face of that pulley, then I can run a hyd pump off of that pulley. We'll see what happens.
   I thank you for your input.
#4 HALFSCALE ONLINE
HALFSCALE
  • 504 Thanks
  • 533 posts
Posted May 31, 2016 - 02:37 AM
The MTD disc with the metal in between is the older style , it was replaced by a solid fiber type. The metal center on the old style really wore hard on the guide pins. As far as I know cub discs are still available  and can be used on a MTD, just rotate and drill for the 4 pin system.
  • Alc, VTXrider and Sawdust have said thanks
