Making axle seals
10 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,374 Thanks
  • 1,331 posts
Posted May 27, 2016 - 03:34 PM
So I'm in the position that I need to make axle seals for my Moto Mower 6020
My dad said I could use cardboard to sop up the oil, to make a barrier for stopping more oil.
Would this work?
He also said I could make some out of some rubber stuff he has, I think it's old belting from a gay baler...
Again, would this work?
  • Marty'70 and CanadianHobbyFarmer have said thanks
#2 KennyP ONLINE
  • 37,377 Thanks
  • 45,442 posts
Posted May 27, 2016 - 03:41 PM
Maybe. For a month or so.
  • boyscout862, CanadianHobbyFarmer and Greasy6020 have said thanks
#3 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,177 Thanks
  • 697 posts
Posted May 27, 2016 - 03:42 PM
It might work as a temporary fix, but I wouldn't chance it. New seals should be under $20 each. How much is a new transaxle going to cost you if you blow it up because you Mickey Moused the seals? Just saying.
Jim
  • boyscout862 and Greasy6020 have said thanks
#4 boyscout862 OFFLINE
  • 12,517 Thanks
  • 9,027 posts
Posted May 27, 2016 - 03:54 PM
Take an old seal out. Measure the ID, OD, and thickness. Match it up at an auto parts or bearing supply place. Good Luck, Rick
  • CanadianHobbyFarmer and Greasy6020 have said thanks
#5 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted May 27, 2016 - 03:59 PM
I told you in your other post these axle seals are still available at any autoparts store you can get them for less than 20 bucks a set.
  • MH81, boyscout862 and Greasy6020 have said thanks
#6 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,177 Thanks
  • 697 posts
Posted May 27, 2016 - 04:13 PM
If you don't have the tools or confidence to measure the old seals, just take them with you and let the people at the auto parts place or bearing shop do the measuring.
Jim
#7 Sawdust OFFLINE
Sawdust
  • 5,561 Thanks
  • 3,335 posts
Posted May 27, 2016 - 04:18 PM
Seals, bearings,sleeves etc. can be found like mentioned most of the time at your local auto store...they just need to see your old one. Using their cross reference charts can save you some money for replacements. Now on more serious parts be careful with some after market parts.
  • Greasy6020 said thank you
#8 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,114 Thanks
  • 2,397 posts
Posted May 27, 2016 - 04:25 PM
I get all my bearings, bushing and seals from Napa, just take in the parts you need and they will measure, like everyone else said it shouldn't cost more then $20 for the set.
Good luck! :thumbs:
#9 Bolens 1000 OFFLINE
  • 14,886 Thanks
  • 18,095 posts
Posted May 27, 2016 - 04:29 PM
Why chance making stuff that is available new, as others have mentioned most stores can help you out
Worst case send me your old seals if you want to and I'll interchange them for you, I am a dealer for National/Timken bearings and seals and normally can sell you seals less than the auto stores
  • MH81, KennyP, boyscout862 and 3 others have said thanks
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 27, 2016 - 11:03 PM
I have made gaskets from breakfast food boxed coated with wheelbearing grease.
Bur in most cases seals are cheap enough it does not justify the time it takes to make one.
Oddly many seals are universal to the point that many seals were in use in something before most of us oldtimers were even born.
example: I broke a tie rod end on a 60 Ford Falcon, My father'in-law  handed me a new one for a 49 F0rd he had on the shelf and it had the same part # and was an exact fit.
#11 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted May 28, 2016 - 12:02 AM
While I have not used your services; I am glad guys like you are out there.
