PLEASE HELP..Photos
41 replies to this topic
#31 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 31, 2016 - 08:28 PM
Is there a possibility that there is something under the ram (downhill end) and its stopping causes the back end to blow out?
I have taken it apart twice..cleaned it..checked everything..its something in the Cyl itself..I put one of the out riggers in place of it and it worked fine but is too short.
#32 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 31, 2016 - 08:29 PM
Most hydraulic places deal with places that can custom build a cylinder to match what you have if you can't find an off the shelf unit to match it.
just dont have the funds for that right now..at this point I am just looking for something that will fit.
#33 MH81 OFFLINE
Posted May 31, 2016 - 08:35 PM
Do you have all the measurements?
#34 MH81 OFFLINE
Posted May 31, 2016 - 08:38 PM
Oh, and I found this info on a Google search
The Power King Tractor Co. now owns them and claim to have lots of parts. Contact them at; 1 877 262 1191' They are in Princeton,Indiana.
  • Auburn David and 29 Chev have said thanks
#35 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 31, 2016 - 10:32 PM
Thank you..will do!
#36 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,509 Thanks
  • 6,185 posts
Posted June 01, 2016 - 08:18 AM
Post up all the dimensions.
#37 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 01, 2016 - 09:38 AM
looks to be 4in across the outside housing/casing and the casing its self without the ram or welded on mounts/hoops is 17in and with ram and hoops retracted its right around 24 in Pictures to follow soon as I can get some..but these are what I have now.
#38 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 01, 2016 - 09:54 AM
that ram might be 2 inches looking at it...hahaha
#39 Alc OFFLINE
  • 7,129 Thanks
  • 7,532 posts
Posted June 01, 2016 - 10:39 AM
Just wondering , when does that cap come off ? While using the that cylinder ( might be called " dipper" )  or when you curl the bucket ?
  • Auburn David said thank you
#40 MH81 OFFLINE
Posted June 01, 2016 - 10:58 AM
http://www.surplusce...E-9-7713-12.axd
Might look at the specs on this one?
#41 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 01, 2016 - 12:08 PM
when I fully retract or get close to retacting the cyl..its the middle one also..just above the dipper/bucket cyl.
#42 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted June 01, 2016 - 12:24 PM
here are some photos with the cap pushed out..please forgive the crappy weld job..I have just been trying to get it to stay together till I can get a different one.
