Got a sparkless 2012
18 replies to this topic
#16 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted May 27, 2011 - 05:57 AM
Ah, so even if I have the sticker I may not have hi-low? That makes sense thanks, Mike.
#17 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted May 27, 2011 - 07:47 AM
If you have a single v belt pulley on the input shaft of the tranny without any extra housing or linkage on it your tractor dosen't have the high-low. The high-low unit is a pretty rare option.
  • middleageddeere said thank you
#18 B10Dave OFFLINE
B10Dave
  • 899 Thanks
  • 368 posts
Posted May 29, 2011 - 10:08 PM
So, you switched it over to an automotive style points and coil ignition? I have done that to several of my tractors too. If and when the engine needs to be removed for repair then I check out problem with magneto ign. Quick and easy to add coil even if it will be temporary. Dave.
#19 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted May 31, 2011 - 06:06 AM
Yes, that is what I did. Works great and was minimal work.
