Help I done goofed...!
13 replies to this topic
#1 WoodyChuck OFFLINE
WoodyChuck
  • 34 Thanks
  • 53 posts
Posted May 25, 2016 - 04:23 PM
I had a 1200 cub running had to adjust carb and clean it to get it going and it ran well except at low speed and then the engine stopped running. I looked and the carb got blown off. What could have caused this and do I need a new carb or does the whole engine need rebuilt and what can I expect to replace to get it going again???
  • hamman and boyscout862 have said thanks
#2 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,641 Thanks
  • 5,044 posts
Posted May 25, 2016 - 04:33 PM
You need a new carb.   Someone has cobbled that broken one back together in the past and it didn't [and won't] hold.
#3 jimbobbillyray ONLINE
jimbobbillyray
  • 3,059 Thanks
  • 2,892 posts
I don't think there is anything wrong with the motor.  it sorta looks like the carb was it already broken before it fell off  .  that's a 12 hp kohler isn't it?  you can find another from a sponsor here or as a last resort on epay
Edited by Delmar, May 25, 2016 - 04:36 PM.
  • boyscout862 and Sawdust have said thanks
#4 WoodyChuck OFFLINE
WoodyChuck
  • 34 Thanks
  • 53 posts
Posted May 25, 2016 - 04:44 PM
It looks like someone did weld it together at some point the entire exhaust of this cub is fabricated....
#5 dodge trucker ONLINE
dodge trucker
  • 2,683 Thanks
  • 3,332 posts
Posted May 25, 2016 - 05:52 PM
last time I saw a kohler carb like that was on a troy bilt tiller that got away and smacked a fencepost thanks to my brother... this wasa 7hp k161 that this happened to....
  • Oldford said thank you
#6 WoodyChuck OFFLINE
WoodyChuck
  • 34 Thanks
  • 53 posts
Posted May 25, 2016 - 06:33 PM
I bet this one couldn't go flying because it was attached by 2 bolts as well as a gas line which are all pretty heavy duty
#7 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,010 Thanks
  • 5,978 posts
Posted May 25, 2016 - 06:46 PM
Before investing $$$ in a new carb do a compression or better yet a leak-down test to be sure the lean condition the thing experienced didn't do any piston or valve issues..  JMHO..
#8 dodge trucker ONLINE
dodge trucker
  • 2,683 Thanks
  • 3,332 posts
Posted May 25, 2016 - 09:43 PM
yeah that one was attached the same exact way... same engine as yours just the smaller version.
#9 WoodyChuck OFFLINE
WoodyChuck
  • 34 Thanks
  • 53 posts
Posted May 26, 2016 - 11:05 AM
I think at this point I might as well take the head off the engine and look at the head gasket and see what the wear is on the inside before I go spending $$$ on it. The clutch release rod was already fabricated by this guy just to get it moving to sell... Had to get help fabricating a better one that doesn't fall off.
#10 lrhredjb OFFLINE
lrhredjb
  • 799 Thanks
  • 616 posts
Posted June 01, 2016 - 08:01 AM
Usually about this time someone suggests using JB weld to fix it. :rolling:
  • WNYTractorTinkerer and WoodyChuck have said thanks
#11 WoodyChuck OFFLINE
WoodyChuck
  • 34 Thanks
  • 53 posts
Posted June 01, 2016 - 11:15 AM
That is what was already done to it 😂
#12 chieffan ONLINE
  • 10,890 Thanks
  • 6,919 posts
Posted June 06, 2016 - 11:57 PM
JB Weld fixes a lot of things and it holds too.  Just have to be reasonable on what you use it on and where..
  • Sawdust said thank you
#13 lrhredjb OFFLINE
lrhredjb
  • 799 Thanks
  • 616 posts
Posted June 07, 2016 - 12:21 PM
I guess some folks have luck with it. Personally I have never been able to say it fixed anything.
#14 Sawdust ONLINE
Sawdust
  • 6,009 Thanks
  • 3,490 posts
Posted June 07, 2016 - 02:16 PM
I think the biggest problem using jb weld is not letting it set up & mixed in a good ratio. I have used it with success but it's not a miracle cure. Even the quick set stuff takes longer than instructed.
