They were calling me!
5 replies to this topic
#1 Alberta Bolens OFFLINE
Alberta Bolens
  • 449 Thanks
  • 258 posts
Posted May 24, 2016 - 11:14 PM
I was outside doing some yard work and heard voices.  It was my 2 newsest acquisitions calling for attention.  I had brought home a Bolens 1000 with a 14 hp kohler in it and a sears suburban 10 in mid April.  At that point I had pulled the plugs squirted in a bit of diesel put the plugs back in and parked them in the tent.  I knew both the engines were not stuck as I had turned them a wee bit by hand.  I had to know more.  Went down with the Bolens 1050 to serve booster duty a few tools and squirt can of gas mix.
Good news is they both turn over with thier starters and seem to have compression and no bad noises.  However they do not seem to have spark.   I knew they would not run on thier own as fuel tanks are cruddy.  But by squirting gas into the carb I was hoping at least one would fire.
Next time they call me I will drag them up to the shop and spend some real time on them.  Plus side I'm pretty certian they will both run with some TLC.
Edited by Alberta Bolens, May 24, 2016 - 11:15 PM.
  • rustyoldjunk, Gtractor, Alc and 9 others have said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,169 Thanks
  • 5,762 posts
Posted May 25, 2016 - 07:47 AM
I have several calling my name, just no time
  • Alberta Bolens said thank you
#3 Utah Smitty OFFLINE
Utah Smitty
  • 1,643 Thanks
  • 1,746 posts
Posted May 25, 2016 - 03:56 PM
Heck, I have so many calling, it's like the Mormon Tabernacle Choir!!! :rolling:  :rolling:
Smitty
  • Cvans and Alberta Bolens have said thanks
#4 Greasy6020 OFFLINE
Greasy6020
  • 738 Thanks
  • 717 posts
Posted May 26, 2016 - 12:26 PM
i have my moto mower calling me, school and work are interfering... it needs axle seals and the new tires mounted on the rims.
#5 LilysDad OFFLINE
LilysDad
    Crazy about GTTalk
  • 10,050 Thanks
  • 7,897 posts
Posted May 26, 2016 - 02:38 PM
Say! I really admire that performance muffler on the Bolens.
#6 Alberta Bolens OFFLINE
Alberta Bolens
  • 449 Thanks
  • 258 posts
Posted May 26, 2016 - 08:44 PM
It has a 14 hp Kohler Muffler tail pipe has holes drilled into the sides the end capped off.  Its a custom part for sure.  LOL
