850 won't start
9 replies to this topic
#1 dmcjt850 OFFLINE
dmcjt850
  • 18 Thanks
  • 80 posts
Posted May 24, 2016 - 08:55 PM
New battery(12.7 volt with a meter) battery will not turn the motor over with out assistance (foot spinning the belt). Selonoid clicks but won't turn start gen, under advice from a friend I tried to repolorize the s/g. Now the selonoid does nothing. I'm guessing the selonoid is bad. Getting frustrated,
#2 boyscout862 OFFLINE
  • 15273 Thanks
  • 10026 posts
Posted May 25, 2016 - 12:06 AM
First guess: bad connection. Check all main connections especially the grounds and battery cables. Good Luck, Rick
#3 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted May 25, 2016 - 01:12 AM
Please explain how you re-polarized the starter/generator. Did you try a 'no load' (remove the belt) start? Age of battery? Checked all connections and wires?
#4 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted May 25, 2016 - 01:13 AM
Also, what is the CCA rating of the new battery?
#5 jabelman OFFLINE
jabelman
  • 2401 Thanks
  • 1668 posts
Posted May 25, 2016 - 05:08 AM
by repolarizing I think he means taking a jumper wire and touching "a" to positive for second
#6 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted May 25, 2016 - 05:48 AM
I would bet that your generator brush springs are seized and not making good contact, easy fix, take the generator apart lubricate and clean and put back together.
You'd be surprised how dirty these get inside.
#7 dmcjt850 OFFLINE
dmcjt850
  • 18 Thanks
  • 80 posts
Posted May 25, 2016 - 05:56 AM
checked all connections, found the "field" connection on the s/g was bad. fixed that. all other connections are good.
pulled the "field" wire off s/g and used a jumper wire from the positive terminal to the "F" terminal on the s/g for 2-3 seconds.
420 cca, brand new battery.
#8 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 25, 2016 - 06:31 AM
Did you try a lead directly to the starter to see if it spins freely?
#9 dmcjt850 OFFLINE
dmcjt850
  • 18 Thanks
  • 80 posts
Posted May 25, 2016 - 08:42 AM
no I haven't, by doing that it would by pass the solenoid correct. how would I go about doing that?
#10 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted May 25, 2016 - 08:16 PM
You need to do some basic troubleshooting.   ....Since you have a voltmeter, it should be easy.
(1) Disconnect the large wire from the armature terminal of the starter.  ....Make sure it does not touch any metal.
(2) Measure voltage between battery-side of solenoid and ground.  .....It should be very close to voltage measured at battery terminals.
(3) While holding the key in the start position, measure voltage between starter-side of solenoid and ground.  .....It should be very close to voltage measured in step 2.
(4) While holding the key in the start position, measure voltage between the terminal you removed from the starter's armature terminal and ground.  ....It should be very close to what you measured in step 3.
(5) Remove the belt from the starter.  .....Does the pulley turn freely, without any drag or roughness?
(6) Reconnect the wire to the armature terminal.  .....Does the starter spin when the key is turned to the start position?  ....Does it spin fast or slowly?  ......Can you keep the pulley from turning while holding it in your hand?
(7) Measure the voltage across the battery terminals while the key is in the start position.  ....What voltage does it read?
A weak battery, corroded terminals, loose connections, etc, will affect the above tests.
Let us know what you find, and we can offer more help.
  • Bolens 1000, MailmAn, ClassicBolens and 1 other said thanks
