Sears DLT Issues
26 replies to this topic
#1 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 21, 2016 - 12:25 PM
I have a Sears DLT mower with the 25 HP Intek in it. Have an issue with it spitting and sputtering with the PTO engaged. Black smoke just rolls. Turn the PTO off, and it will smooth back out again. I have checked everything I can according to the manual. It has new plugs and the valves have been adjusted. New oil change, air filter. I pulled the flywheel this morning to check the key there and all is good. Ran a diode test and they check okay. Cleaned the inside of the flywheel and it charges better now. Also, if you let it set overnight, takes a squirt of carb cleaner to get it to fire. I have an electric fuel pump on it and that didn't help with any of the issues. I'm thinking the coil pacs are getting weak, missing under load. Any other ideas?
Here's the plugs. Only an hour or so run time on them.
This was inside the flywheel.
#2 boyscout862 OFFLINE
  • 10,505 Thanks
  • 7,927 posts
Posted May 21, 2016 - 12:31 PM
Aren't those engines notorius for camshaft problems? Measure the low point and high points of the valves to see if there is adequate lift. Good Luck, Rick
#3 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 978 posts
Posted May 21, 2016 - 02:40 PM
Did you clean the carb Kenny. Lots of mine that I have that ran funny under load had dirty jets
#4 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 21, 2016 - 02:49 PM
Haven't done that as yet. But I did pull the bowl off and it was clean.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,172 Thanks
  • 5,770 posts
Posted May 21, 2016 - 04:11 PM
Sounds like low secondary ignition voltage
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,172 Thanks
  • 5,770 posts
Posted May 21, 2016 - 04:21 PM
Coil packs getting proper voltage?
#7 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted May 21, 2016 - 04:35 PM
I'm sure you're on the right track, but one thing to keep in mind... Mine would do weird "under load" stuff and it ended up being a partial clogged fuel filter.
Shouldn't have acted the way it did, but that's what fixed it.
#8 bbuckler OFFLINE
bbuckler
  • 2,366 Thanks
  • 2,139 posts
Posted May 21, 2016 - 04:40 PM
I got the same mower with the governor shot.
#9 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 21, 2016 - 04:54 PM
I have ruled out a carb problem as it will run great until a load gets on it. Then it floods and black smoke rolls. Kick the load off and it smooths right up. Might be a governor, but I'm leaning toward the coil pacs. Weak spark will do the same. And this will not start with full throttle and choke after sitting overnight. Needs some carb cleaner spray and fires right off.
#10 EricFromPa ONLINE
EricFromPa
  • 2,675 Thanks
  • 2,544 posts
Posted May 21, 2016 - 04:55 PM
Those were known for the rings wearing out rather fast because of the Seal on the air cleaner not sealing.Plastic intake boot? Warps and the gasket gets hard from the heat.
I do see quite a bit of dirt sticking on the inside of your intake.That can't be good for it.
I would pull the carb off and take it apart and spray it out really good with carb cleaner and see if that helps any.
Here's a really good link to what needs taken apart and what needs cleaned in a 2 barrel Nikki carb.
http://outdoorpoweri...-twin_carb2.asp
Don't forget the Main jet is in the bowl and the fuel solenoid shuts fuel off by directly closing off the main jet.So if the solenoid is dirty or sticking slightly then it will not open up the whole way and cause it to run lean.
$5 can of carb cleaner is cheaper than a $80 coil set.
Edited by EricFromPa, May 21, 2016 - 04:57 PM.
#11 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 21, 2016 - 05:02 PM
Coil set is on order! Be here next week. I'll have to take the intake off to get the carb off as it sits inside it.
#12 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 25, 2016 - 03:08 PM
Got the coil set and swapped them out. Old ones had lamination's coming apart. Fired up with a little choke and did fine. Turned the PTO on and gave it some RPM's. Did well, no smoke nor miss. Then I heard a funny noise and all it has now it full (+) throttle. Tried adjusting the governor to no avail. Either wide (+) open or just an idle. Think the governor gave it up!
#13 bbuckler OFFLINE
bbuckler
  • 2,366 Thanks
  • 2,139 posts
Posted May 25, 2016 - 08:20 PM
Common problem I have had two in a row like that. Have you seen the inside of the carb ? there is a lot of plastic.
#14 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 26, 2016 - 05:32 AM
I pulled the carb apart and squirted carb cleaner through it everywhere. It was running great for a couple minutes. Hope my hand heals up soon so I can pull the engine and change the governor out.
#15 KennyP ONLINE
  • 31,340 Thanks
  • 41,555 posts
Posted May 26, 2016 - 06:42 AM
Just ordered the governor. May be the first of the week before I get it. I'm trying to get this running good to take to my son in Wichita as he needs a decent mower. I'll get Steve to help with getting the engine off and on a table to tear it apart.
