This can be Addicting.....
7 replies to this topic
#1 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,213 Thanks
  • 2,951 posts
Posted May 21, 2016 - 12:12 PM
Taking home another Ford lgt today. This one comes with a three point hitch, tiller, and 42" mower deck.
Edited by Delmar, May 21, 2016 - 02:27 PM.
  • Gtractor, MH81, Alc and 7 others have said thanks
#2 case1man OFFLINE
case1man
  • 227 Thanks
  • 154 posts
Posted May 21, 2016 - 12:54 PM
Nice find . Looks like the one I was watching on ebay
  • jimbobbillyray said thank you
#3 KennyP OFFLINE
  • 41,455 Thanks
  • 47,383 posts
Posted May 21, 2016 - 12:58 PM
Nice! That 3-point is a hard item to find for these.
#4 Bolens800uk OFFLINE
Bolens800uk
  • 1,851 Thanks
  • 1,208 posts
Posted May 21, 2016 - 05:07 PM
Nice find. Be great to see some more photos especially the hitch.
#5 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,213 Thanks
  • 2,951 posts
Posted May 21, 2016 - 09:34 PM
Kenny, thank you for uploading the jac 3-point hitch manual. I was able to identify what I had.  the p o didn't find all the parts in his barn for the 3-point, all he had was the 2 lift arms, the center shaft, and the center pivot point bracket.  he said if he found the rest he would let me have it.  I figure it's a good start on a three point tho.  I can maybe use the tiller shaft mount brackets as a pattern to make brackets for the 3-point shaft.  I have an extra set of lower arms from an FF that should work too.
#6 KennyP OFFLINE
  • 41,455 Thanks
  • 47,383 posts
Posted May 22, 2016 - 04:53 AM
The Ford lower arms are not even close to the FF. Here the drawing for those.
#7 Alc ONLINE
  • 7,348 Thanks
  • 7,633 posts
Posted May 22, 2016 - 05:25 AM
The tractor doesn't look too bad the tiller looks in very good condition from trying to see the wear on the tines is it ?
#8 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,213 Thanks
  • 2,951 posts
Posted May 22, 2016 - 05:19 PM
The first one I brought home is a closed side lgt 145, has a tiller, motor is toast.  Looks complete.   The second one I brought home a couple of days ago is also a closed side 145.  after changing the condenser and spark plug, it runs great.  It came with a 48 inch snow blade, 50 inch mower deck, and wheel covers.  This is the one I was going to restore, using the first 145 as a parts tractor.
Then the 165 open side came up for sale and I couldn't pass it up.  The lift cylinder is bad on it, the fender deck is just about rusted thru, and someone opened a new hole in the hood (looks like they used a torch) when they replaced the gas tank.  I will end up selling the running 145 and keeping the 165.
011.jpg                              See, I told u it was addicting.... :thumbs:
Edited by Delmar, May 22, 2016 - 07:10 PM.
  • Gtractor and skyrydr2 have said thanks
