Carb tap size
2 replies to this topic
#1 cootertom ONLINE
cootertom
  • 1,351 Thanks
  • 724 posts
Posted May 20, 2016 - 08:45 PM
1961 Penn. Panzer Carb, does anyone know the correct tap sizes for the jets. I need to clean then out and correct the threads from where they were seized.
#2 boyscout862 ONLINE
  • 10,332 Thanks
  • 7,824 posts
Posted May 21, 2016 - 05:45 AM
What engine? The older B&S had a pair of special taps for chasing the threads in the carbs. They came in a plastic case from B&S. Use the removed piece to get the size. I remember one time taking the removed piece, using a file to clean the threads and make a notch so that the old piece could chase the threads. I had already gotten a replacement. The chaser worked okay but, I had to work very slow. Good Luck, Rick
#3 cootertom ONLINE
cootertom
  • 1,351 Thanks
  • 724 posts
Posted May 21, 2016 - 08:45 PM
Engine is a Briggs model 142302---series 250547----type 502056
