Gilson hydrostat fluid?
5 replies to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,388 Thanks
  • 4,692 posts
Posted May 20, 2016 - 07:02 PM
I know the manual says to not mess with the fluid and to take it to an authorized dealer, but......
I want/need to change the hydraulic filter, and I know I lost fluid while it was upside down being painted.....So, what kind of filter & fluid, and how much??
Thanks!d
1970 Gilson S-14 H
Edited by KC9KAS, May 20, 2016 - 09:46 PM.
#2 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted May 20, 2016 - 09:53 PM
Eaton 12 on 2 speed Peerless transaxle.
If I remember correctly they take Dexron III ATF.Not sure on the filter but your local Napa can hook you up if you bring your old filter with you.
  • KC9KAS said thank you
#3 KennyP ONLINE
  • 38,453 Thanks
  • 45,964 posts
Posted May 21, 2016 - 04:15 AM
Might want to read this! I have been using a Trans/Hydraulic oil in all my Eaton/Peerless combos when I change fluid & filter.
#4 KC9KAS ONLINE
KC9KAS
  • 5,388 Thanks
  • 4,692 posts
Posted May 21, 2016 - 09:23 AM
I think the hydro unit is a VICKERS brand.
#5 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted May 21, 2016 - 11:38 AM
Does the transaxle look like This?
Vickers Unit.Manual states to use ATF Type A or B
http://gardentractor...-vickers-t66-2/
Or Eaton 12 unit.
We're still looking for some manuals that were missing for the late 60s early 70s Gilsons/Wards and early to mid 80s Gilson/Wards.I gathered up as many as I could get from the Gilson/Wards Yahoo group and several other forums but we're still missing the early and late model Service manuals and a couple parts manuals.
You have to remember that these larger Gilson/Wards tractors were quite a bit more expensive than alot of the tractors at the time.Most were sold to Golf courses,state parks,government run origination's and people with money.So manuals are really hard to get ahold of.
I bought 5 of the 6 that I had at State Auction.2 Were used at a golf course 3 were used at a local State Park.Out of the 6 that I had only 2 were salvageable.3 had broken frames,1 had bad hydro and 3 had a blown or worn out engines.The only 1 that I got that was privately owned was the old Blue 16 Twin.It also had a cracked frame but was fixable.
Edited by EricFromPa, May 21, 2016 - 12:04 PM.
#6 Sprint 6 ONLINE
Sprint 6
  • 246 Thanks
  • 301 posts
Posted May 22, 2016 - 07:37 AM
My original manual states Type A trans fluid, which would correspond to Dexron III today.  What manuals do we need?  I have the original parts and owners manual for the 1974 MW 16 my grandpa bought new.
