My first Case--a 442
15 replies to this topic
#1 JBRamsey ONLINE
JBRamsey
  • 1,230 Thanks
  • 714 posts
Posted May 20, 2016 - 05:25 PM
I took the back exit from my optometrist today and see a Case 442 behind a fence under a shed roof. I stop in, ask if they were interested in selling and now I own a 442. I'll pick it up Sunday afternoon.
I know zero about a Case other than I think they are cool looking. I know this one doesn't have the original engine, but it turned over easily with the starter. I suspect it has hydraulic issues because the owner said it would slow down after running a while. image.jpeg image.jpeg image.jpeg
  • Gtractor and Oldford have said thanks
#2 Gtractor ONLINE
Gtractor
    The Tractor Hoarder
  • 8,062 Thanks
  • 4,469 posts
Posted May 20, 2016 - 05:52 PM
That's a heck of a good find!  :thumbs:
BTW,  442 is an Oldsmobile  :poke:
  • Oldford, Auburn David, JBRamsey and 1 other said thanks
#3 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 20, 2016 - 05:58 PM
I have a 6018 with a Backhoe and FIL..having issues with the drive plate..that might be the problem with yours.
  • JBRamsey said thank you
#4 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 20, 2016 - 05:59 PM
Meet Frankin Tractor..it has a Kohler on it now as well...LOL
#5 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 20, 2016 - 06:00 PM
sorry its upside down..its right om my PC..just upside down on this site..Hope an admin will fix it.
#6 dropped82 ONLINE
dropped82
    Nut Case
  • 1,990 Thanks
  • 1,531 posts
Posted May 20, 2016 - 06:08 PM
That's actually a 446 with a twin 16 hp onan. Great machines. I've got a few. Last digit in the model number designates HP.
From what I see, that's an all original machine. The hood is supposed to be cut like that for the twin mufflers. It's hard to find them with the twin mufflers still intact.
Eric
Sent from my SPH-L720T using Tapatalk
Edited by dropped82, May 20, 2016 - 06:10 PM.
  • Oldford and JBRamsey have said thanks
#7 Bill 76 ONLINE
Bill 76
  • 1,786 Thanks
  • 1,129 posts
Posted May 20, 2016 - 06:32 PM
Your eyes must be ok if you spotted it behind a fence  :wave:
#8 JBRamsey ONLINE
JBRamsey
  • 1,230 Thanks
  • 714 posts
Posted May 20, 2016 - 06:47 PM
Apparently I'm dyslexic.
#9 JBRamsey ONLINE
JBRamsey
  • 1,230 Thanks
  • 714 posts
Posted May 20, 2016 - 07:02 PM
I have never moved that quickly on buying anything. I knew that the big wheel Case tractors are desirable and can bring big money. That's pretty much my knowledge. When I opened the hood and saw the hydraulic tank and cooler, I knew I was in. The guys wife gave me his number, I called and we made a deal. It was so fast I didn't distinguish between 442 and 446! If I get it working properly and round up a hitch and a plow, I'll sell off at least two of my Suburbans, if not all three.
#10 petrj6 OFFLINE
petrj6
  • 4,076 Thanks
  • 2,369 posts
Posted May 20, 2016 - 07:52 PM
   you will love that thing, I have had two or three and they are all very nice machines, I never could get used to the hydraulic drive on them, if it slowing down when hot the first thing I would look to do is change the fluid, those tractors use heavy duty motor oil like a 15w-40 or something close.  Do not use hydraulic oil !!!! good luck with it.
                            Pete
#11 glgrumpy ONLINE
  • 7,720 Thanks
  • 7,337 posts
Posted May 20, 2016 - 08:36 PM
Rotella 15w-40 oil is the recommended one on the Case forums.  It is a Diesel oil or HDuty also, good stuff.
#12 dropped82 ONLINE
dropped82
    Nut Case
  • 1,990 Thanks
  • 1,531 posts
Posted May 20, 2016 - 09:05 PM
You did good. The hydraulic drive is a little different and takes time to get used to. In your pictures, I see a sleeve hitch. You may look around for other attachments ie: plow, disc, blade, tiller. That hitch is there for a reason. Once you get it going, I'd recommend changing the hydro fluid and also decarboning/valve lash on the onan. I also use 15w40 Rotella in all mine. Great oil and inexpensive. The rearend on these has its own oil also and should be changed. You can also use the 15w40.
Eric
Eric
#13 JBRamsey ONLINE
JBRamsey
  • 1,230 Thanks
  • 714 posts
Posted May 20, 2016 - 09:32 PM
When I pick it up on Sunday, I will ask if he has any attachments. He said his daddy owned it for over 25 years. I bet something is around somewhere. I'd love to have a front plow and a tiller. If I can get those, I won't need my Suburbans.
#14 JBRamsey ONLINE
JBRamsey
  • 1,230 Thanks
  • 714 posts
Posted May 22, 2016 - 07:44 PM
I picked it up today. It turns over good but no fire at the plugs. Ran a mouse out turning it over. Before I go further, I think I'll pull it apart some and clean everything out. That will have to wait until next weekend. I spend the next four days in Des Moines.
Based on the serial number, it's a 73 model. The guys Dad bought it new. He had a plow but said "it's long gone."image.jpeg image.jpeg image.jpeg
  • Gtractor said thank you
#15 dropped82 ONLINE
dropped82
    Nut Case
  • 1,990 Thanks
  • 1,531 posts
Posted May 22, 2016 - 07:56 PM
Pull the tins and clean the engine. Change the fluids. It's probably just a points and carb cleaning away from running. You got a great machine that looks taken care of. It'll give you many more years of service.
