Lines are right on the 6018
3 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 20, 2016 - 03:46 PM
I need to figure out how to adjust the drive plate(banana plate)  I guess.I installed a new one a few months ago..Prior to that it wouldn't move at all.I also replaced the UV joint..friction washer and other related parts..but I know it isn't adjusted right...Off to see if I can figure out how to adjust it.
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 20, 2016 - 06:03 PM
Well no luck figuring out how to adjust the plate..is there a procedure?
#3 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted May 20, 2016 - 07:19 PM
Just a thought is the travel lever shoulder bushing seating in the notch in end of banana plate?
  • Auburn David said thank you
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 20, 2016 - 07:51 PM
I am sure its not..but I cant find the steps on how to adjust it like it should be.
