Power king 48 inch mower deck
5 replies to this topic
#1 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted May 20, 2016 - 02:51 PM
Been searching for the size of the drive belt but no luck. It is a pk 1614 54463 with 48 inch deck. Thanks
#2 MNGB ONLINE
MNGB
  • 2,138 Thanks
  • 1,415 posts
Posted May 20, 2016 - 05:26 PM
The numbers I have and the belt I use on my tractor is an A83  1/2"X85"  PK number is 81-0085
#3 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted May 20, 2016 - 05:52 PM
Thanks mngb. Never put it on guess I will  see if it works.
Edited by jjln50, May 20, 2016 - 05:53 PM.
#4 MNGB ONLINE
MNGB
  • 2,138 Thanks
  • 1,415 posts
Posted May 20, 2016 - 06:54 PM
Hi jjln50, actually its not to hard of a deck to install once you have done one, which deck do you have (I know its 48") but does it have the standard hitch or the parallel hitch? I have one of each but have not installed the standard hitch model but have installed the parallel one  just did it this afternoon they tend to be a noisy (loud)deck but they cut very nice and can handle fairly tall grass. I find having a prybar and some 2X4 blocks to hold the deck up while attaching the pins / bolts makes it a lot easier.
  • jjln50 said thank you
#5 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted May 20, 2016 - 08:50 PM
I"m not sure which it has a mule if that helps. Once I get the plow off it looks to be pretty straight forward. But I'm sure you know how that goes. lol
#6 MNGB ONLINE
MNGB
  • 2,138 Thanks
  • 1,415 posts
Posted May 20, 2016 - 08:56 PM
Hi Power King calls them a hitch many myself included refer to them as a mule drive, the standard hitch / mule is the older type and the parallel is a new style do you have a manual for the mowers if not there is one in the manuals section here on site.
