been wanting to do this for a while now , have got this Toro cutter deck twin cut 38"from curbside
so went to refitting it to my Rover Rancher 2 ,
still have to cover the outlet section as the blade extrude out
still to fit the neutral lever
got to reset the front carry wheels about 1&1/2" lower as the front sets to low in cut
I do have 1 delamer the 10HP briggs is struggling to cut heavier (longer ) grass so opting to fit 1 of the 12 HP B&S engines or the 16 HP twin Vanguard engine ,
got to test that 1 ,1st though or opt to swap the pulley on my machine to change cutter ratio a bit
the top linkage slides in a sleeve for flexibility on uneven ground
Shane
