Frankin tractor is useless Help.
8 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 19, 2016 - 09:43 PM
I dug a tail ditch today with Frankin Tractor(Ingersoll 6018 with a Backhoe )bucket and Backhoe are too responsive..but forward and reverse power suck bad..could I have the hydro hoses on the pump reversed?..I know the new drive plate isn't adjusted right..but it lacks power forward and revers.. Help needed Please
It digs great..if you can get it up the hill to where you want to dig..
Edited by Auburn David, May 19, 2016 - 09:46 PM.
#2 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 19, 2016 - 10:07 PM
Any chances of finding manuals with hydraulics routing plan??  Have seen that for others, like my late Power King.
  • Auburn David said thank you
#3 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted May 19, 2016 - 10:59 PM
Your travel is rear pump  if your lines line up on both pumps just backtrack from front pump to see what line goes to tank or control. The rear plumbed same. To see if crossed. Have to ask is transaxle in low. Probably have to do pressure check on pump.
#4 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted May 20, 2016 - 03:44 AM
It digs great..
Sounds like the travel lever isn't fully contacting the spool, a linkage issue.  easiest and most common thing to check
  • Alc and Auburn David have said thanks
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 20, 2016 - 04:05 AM
Backhoe and loader should be responsive but not fast or hard to control, sounds like you may in fact have the 2 circuits swapped.
If plumbed properly( not sure how they did it?) The perifial ( hoe/ loader) pump should feed backhoe valve first, as its the largest consumer of oil, the from its PB port to the loader valve and on to oil cooler and tank.
Drive should go to motion control valve, hill control ( if equiped) cooler then tank. Sometimes the split return oil flow and only send a portion to cooler, this helps take the load off the cooler and actually makes it more effcient.
Not sure of yoyr particular unit, never worked on one, but what i have described is usually how Case does it on their full sized rigs.
  • Alc, jpackard56 and Auburn David have said thanks
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 20, 2016 - 07:43 AM
I will go out and check all this this week end once the rain stops falling...see if I can find the issue.It has a 2 stage pump,one larger than the other
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted May 20, 2016 - 08:12 AM
I would think that if those are reversed, it would certainly cause some of the issues you're describing.
#8 toppop52 OFFLINE
toppop52
  • 5,546 Thanks
  • 4,906 posts
Posted May 20, 2016 - 08:29 AM
My 4041 has valves that can be closed with levers to direct flow to bucket roll/3 point.
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 20, 2016 - 09:09 AM
Cant really seem to find a circuit drawing..I am going to try to reverse them and see what happens.
