How to put pix between postings?
4 replies to this topic
#1 glgrumpy ONLINE
  • 8,742 Thanks
  • 7,978 posts
Posted May 19, 2016 - 09:22 PM
See some guys on here putting a comment on post, then a picture, followed by more comments and a diff picture. How does that get done??  All I get when downloading pix is all at bottom of post. With my new Bolen's would like to put one pix at time and ask about it, then keep going to next question, all one post.  I can now add another post below one I made first, but uses up much more space and seems I'm talking to myself then, heh! :smilewink:
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 19, 2016 - 09:33 PM
In the "More Reply Options" tab Chose all the pic files you want to post and as you write your post you will have the option of adding the pics one at a time to where your cursor is located.
Hope that helps.
  • MH81, HDWildBill and sodisr have said thanks
#3 glgrumpy ONLINE
  • 8,742 Thanks
  • 7,978 posts
Posted May 19, 2016 - 10:05 PM
I'll try that later then, thanks!
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,279 Thanks
  • 10,116 posts
Posted May 19, 2016 - 10:50 PM
I type, then choose file. When pic is chosen, hit attach this file. When the pic loads, it's a file description above the choose file button on the left side, to the right side it says add to post. Make sure the cursor is where you want the pic, and click add to post.
The pic script will appear in your reply. Click to the right of the ] at the end of that line, hit return to get on a new line, and start typing.
Repeat as necessary.
  • ducky, MH81, HDWildBill and 1 other said thanks
#5 HDWildBill OFFLINE
  • 8,978 Thanks
Posted May 20, 2016 - 09:01 AM
I think the guys have pretty much covered it above.  The only thing I would add is that if you mess up don't worry.  Highlight from "[" to "]" and right click choose "cut" from the menu and then place the cursor where you want the pic and then right click again and choose "Paste".  You can manipulate the script just as you would text.
  • sodisr said thank you
