332 John Deere lawn tractor
4 replies to this topic
#1 dougpuzo OFFLINE
dougpuzo
  • 2 posts
Posted May 19, 2016 - 08:43 PM
My 332 diesel starts and runs until you move the hydrostat lever to move the tractor forward or backwards.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,015 Thanks
  • 10,013 posts
Posted May 19, 2016 - 10:58 PM
Does the engine lug down like it's working hard or does it shut down like you turned off the switch?
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 20, 2016 - 11:20 AM
Good question! my 318 had a neutral safety swith on the hydro lever that got out of adjustment and would do that.
#4 dougpuzo OFFLINE
dougpuzo
  • 2 posts
Posted May 20, 2016 - 06:02 PM
The engine shuts off. Also while running in nutruel PTO on shuts engine off also their are no dash lights none
#5 dropped82 ONLINE
dropped82
    Nut Case
  • 2,501 Thanks
  • 1,818 posts
Posted May 20, 2016 - 06:05 PM
Seat switch. That's what the central box does when there is no passenger. Will shut off pto while not moving. Will shut tractor off when removed from neutral when no one is in the seat.
Eric
Sent from my SPH-L720T using Tapatalk
Edited by dropped82, May 20, 2016 - 06:06 PM.
