Woods 6140
7 replies to this topic
#1 terry.henehan OFFLINE
terry.henehan
  • 4 Thanks
  • 3 posts
Posted May 19, 2016 - 08:41 PM
I recently aquired a Woods 6140 zero turn, it mow's really well the three times I used it.
 The forth time the blades just stopped. The blades spin freely, the drive shaft turns freely, battery has full charge.
Any suggestion's
  • reneeic1, jacquelinezq60 and randallxn16 have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted May 19, 2016 - 11:03 PM
What is the condition of the drive belt on the deck?
  • terry.henehan said thank you
#3 retired1990 OFFLINE
retired1990
  • 3 Thanks
  • 5 posts
Posted May 20, 2016 - 05:31 AM
Look for a shear pin
#4 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted May 20, 2016 - 06:45 AM
I believe those are build by Grasshopper. I would check to make sure you didn't blow a fuse, the PTO switch could have went bad or PTO clutch is bad. I would check all the belts and wiring/fuses before getting too deep into it. The main drive pulley on the back does have a large key in it, could have sheared it also, but for it to have just stopped sounds like and broken belt of electrical issue.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 20, 2016 - 09:55 AM
:welcometogttalk: :camera:
#6 terry.henehan OFFLINE
terry.henehan
  • 4 Thanks
  • 3 posts
Posted May 21, 2016 - 10:58 AM
Thank's for the responses. Got it working thank's
Edited by terry.henehan, May 21, 2016 - 01:21 PM.
#7 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted May 23, 2016 - 07:04 AM
What did you find was wrong?
#8 terry.henehan OFFLINE
terry.henehan
  • 4 Thanks
  • 3 posts
Posted May 24, 2016 - 04:04 AM
It's been running off the battery and not charging.
  • TAHOE said thank you
