Briggs torque specs clarification
1 reply to this topic
#1 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted May 19, 2016 - 03:16 PM
OK so I have a Briggs model 289707. Needing torque for the head bolts. Asked a local shop and a few others and got several answers. One said 22-25 lb/ft. Another said only about 12-15 lb/ft. Checked in the manuals section and ground a PDF file and the best could figure it said 185 lb/in which is about the 12-15 I was told. I guess I'll just throw it out there and see what you guys think....
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,458 Thanks
  • 5,765 posts
Posted May 19, 2016 - 03:43 PM
185 Inch lbs = 185/12 foot lbs.
or solved = ~ 15 foot lbs
The 22/25 foot lbs is most likely for an iron or steel block.
Check this Webpage with your full Model # and code here
  • Marty'70 said thank you
