specific electrical questions
24 replies to this topic
#16 KennyP ONLINE
  • 38,227 Thanks
  • 45,861 posts
Posted June 19, 2016 - 10:43 AM
Good to hear you are getting things figured out. That seat was a bit loose!
#17 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted June 21, 2016 - 03:17 PM
HEY SUCCESS !   I recently finished attaching the rebuilt SG and the correct VR. Checked all the wiring AGAIN , connected the battery, and turned the key to start…….The 800 is now generating power, the gauge is responding perfectly and everything looks like a go !
Thank you so much for every ones help and advice. Until next time.   M
  • dualresponse1731 said thank you
#18 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted June 21, 2016 - 03:24 PM
Yes…that seat was quite loos. I thought it was a goner but some lawn forum research gave me a plan to fix it. A little cleaning, some high heat weld-bond and peening all around the seat was the trick. I was able to clean all the junk from the cylinder head and re-torque the head bolts which were way "loose" before.
Making my own valve retainer removal and install tool was a small challenge but fun. Those official valve spring tools for small engines are not easy to find and usually days away on a fedex truck.
#19 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted June 21, 2016 - 03:27 PM
Kinne electric in Manchester NH is the place to go for electric issues such as old generators ETC. They helped me on a 1948 chrysler starter as well as the 1968 (or so) Jacobsen generator starter.
#20 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted June 22, 2016 - 02:40 PM
The above instructions for polarizing the generator by touching + to A are correct for neg. ground. U may  have to redo this any time the VR or SG are
disconnected!
#21 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted June 23, 2016 - 11:32 PM
Thanks Big John…. I got instructions from the rebuilder that since he had the VR and SG together, and could test and polarize them together, I would not need to.  So far, the system is doing fine.  Bit of an ordeal, but I like to solve things….eventually !
#22 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted July 02, 2016 - 07:01 PM
The 800 is back in business. More cleaning and painting to come. The original tires may be ending their lives in the not too distant future. But they hold air !
#23 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted December 04, 2016 - 08:07 PM
800 ready for snow with its newly (partially) rebuilt jacobsen snowblower
#24 mpeck3 OFFLINE
mpeck3
  • 49 Thanks
  • 45 posts
Posted December 04, 2016 - 08:08 PM
the 800
  • MH81, Alc and KennyP have said thanks
#25 MH81 OFFLINE
Posted December 04, 2016 - 09:47 PM
Looking good!
