Kohler k482 crankshaft seal replacement
2 replies to this topic
#1 Bud W OFFLINE
Bud W
  • 353 Thanks
  • 318 posts
Posted May 18, 2016 - 01:07 PM
I'm replacing the engine in one of my Bolens 1886's and the K482 I want to put in has a slight leak at the crankshaft seals. Does anyone know if I can replace the front and rear seals on this engine without taking the front & rear plates off?
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,800 Thanks
  • 986 posts
Posted May 18, 2016 - 01:44 PM
Yes they can, seal puller works best getting old ones out, rear is very easy, front tougher, make sure you LUBE THEM UP GOOD before seating new ones, make sure you have the correct OD driver PVC works well, and do not set them to deep, you do not bottom them out.
  • Bud W, Lmiller3358, CRFarnsworth and 3 others have said thanks
#3 Bud W OFFLINE
Bud W
  • 353 Thanks
  • 318 posts
Posted May 19, 2016 - 07:06 AM
I thought they could. I'm gonna give it a try.
