JD integral hitch lift link
12 replies to this topic
#1 jcallan OFFLINE
jcallan
  • 12 posts
Posted May 10, 2011 - 05:34 PM
Hi folks. Would any one out there be able to give me the length of the lift link used on the integral hitch for the John Deere 200 series garden tractors as well as where the pin holes are located on each end and diameter of the holes? I lost mine in a move and would like to get the hitch back on the tractor so I would like to fabricate my own. I know there is a blue print on here for one but that is the one for the 300 series.
Edited by jcallan, May 10, 2011 - 06:08 PM.
#2 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted May 12, 2011 - 02:20 PM
#3 Texas Deere and Horse ONLINE
  • 14,866 Thanks
  • 15,512 posts
Posted May 12, 2011 - 02:26 PM
Tmo, Thanks so much for helping out on this, I knew if anyone had a drawing, it would be you. !!!!!!:thumbs:
#4 jcallan OFFLINE
jcallan
  • 12 posts
Posted May 14, 2011 - 10:17 AM
Thank you very much for the replies however that is not the part that I am in need of. I have that one. I may have called it the wrong thing so I am posting the image from the JD parts catalogue here for the visual. I need part number 8 from the diagram. Hope this helps.
#5 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted May 14, 2011 - 11:34 AM
[ATTACH]14603[/ATTACH]
look like deere make several different that should work
checked the length of mine the No 7 the holes are around 11 1/4" apart
the other one No 21-23 the holes are around 12" apart
also if you got a tiller the for is about the same length, but the holes are different sizes
#6 jcallan OFFLINE
jcallan
  • 12 posts
Posted May 14, 2011 - 12:45 PM
Thanks for the reply. It looks like No. 7 is the piece I need. Should not be to hard to make something up that will work.
Thanks again.
#7 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted May 17, 2011 - 12:37 PM
I just now seen the latest on this thread. Here's a drawing that I have done for that part.
  • Texas Deere and Horse, KennyP, pumpkintoter and 1 other said thanks
#8 KennyP ONLINE
  • 40,238 Thanks
  • 46,811 posts
Posted May 18, 2011 - 04:21 AM
Tmo, I don't have a JD, but these drawings can be inspiration for other builds. Thanks for posting them.
#9 jcallan OFFLINE
jcallan
  • 12 posts
Posted May 21, 2011 - 10:16 AM
You guys are awesome. Thank you.
#10 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 21, 2011 - 11:54 AM
Could you also make one of those with 2 thread on clevis ends and threaded rod. The only problem I see is the odd diameter of the holes.
#11 KennyP ONLINE
  • 40,238 Thanks
  • 46,811 posts
Posted May 22, 2011 - 06:56 AM
Couldn't those holes be taken out to a larger diameter? I wonder why they made them so odd.
#12 lyall ONLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted May 22, 2011 - 08:56 PM
if you have a 31 tiller it uses a larger pin to hook to the tiller and but uses the same size pin to hook to the lift as the hitch
the lift rod or lift link are about the same length between the holes for the tiller and hitch
you can drill the hitch hole to the same size that the tiller has
that way you can use same on both the tiller and hitch
just in case you loose one or the other (lift rod / lift link)
#13 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted May 23, 2011 - 06:27 AM
Holes are for a 3/8 diameter pin, so you need a slightly larger hole for clearance. If you had the complete assembly except for the link, you could bore out those holes and the mating holes to fit any pin you want, as long as you don't jeopardize the integrity of part.
