LT1642 won't stay running
12 replies to this topic
#1 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 17, 2016 - 08:26 PM
It is model 135G660G118. 11HP BS 6sp. New fuel filter. Checked lines decent battery plug has spark. I can't figure it out.
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 17, 2016 - 08:59 PM
Little more info would be great..how long will it run to start with?
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 17, 2016 - 09:01 PM
Dirty tank can cause one not to run long(will start after it sets for some time..but die after fuel in bowl is gone)
#4 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 17, 2016 - 09:08 PM
If I fiddle with it I can get it to run for about 10-15mins. The trick is to get it to run. I have to choke by hand since the cable is missing.
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 17, 2016 - 09:11 PM
You have trash in the carb..you need to clean it out..put a kit in it ..and check that no trash is in the tank.
  • STEELRAIN13F said thank you
#6 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 17, 2016 - 09:13 PM
I will look that info up tonight and dig into it tomorrow. Thank you for the help.
  • Auburn David said thank you
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 17, 2016 - 09:15 PM
Might not need a kit if you can save the gaskets..does it have a shut down solenoid?
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 17, 2016 - 09:17 PM
Should be a cheap fix..just a little time.
#9 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 17, 2016 - 09:26 PM
Are you referring to the dead man set switch? If so yes. I don't know much about it yet just picked it for $60 today. It's in good shape just running rough.. I now have the tractor bug. Bought 4 in 3 days...
Edited by STEELRAIN13F, May 17, 2016 - 09:30 PM.
  • boyscout862 and Auburn David have said thanks
#10 boyscout862 ONLINE
  • 12,850 Thanks
  • 9,171 posts
Posted May 17, 2016 - 11:18 PM
Download the newer B&S Repairmans Manual and follow the trouble shooting guide. Good Luck, Rick
#11 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 18, 2016 - 07:58 AM
:camera: :camera: :camera:
#12 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted May 18, 2016 - 08:27 AM
What IF you took the fuel line lose at the carburetor and ran the fuel into a clean container until the tank emptied ( then you would rule out the tank, fuel line and filter)? Then have it ready to remove the carburetor if need.
Just a thought !
Gratton
  • Auburn David and STEELRAIN13F have said thanks
#13 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted June 28, 2016 - 06:40 PM
Ok, it's been a while. I've got it running, but it will only run with the throttle set on high. If I move it it chokes out and dies. Any thoughts?
