308-8 pto
16 replies to this topic
#1 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted May 10, 2011 - 04:04 PM
The engine stalls when it's PTO is engaged I have every wire hooked up correct to the safety switches it runs my tractor I'm not missing any extra wires .
  • 14,814 Thanks
  • 15,502 posts
Posted May 10, 2011 - 04:29 PM
does it have mechanical pto or electric pto?
#3 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted May 10, 2011 - 04:34 PM
Does it bog out or just totally cut out?
#4 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted May 10, 2011 - 04:43 PM
mecanical pto
#5 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Toatally cuts out
#6 Texas Deere and Horse ONLINE
  • 14,814 Thanks
  • 15,502 posts
Posted May 10, 2011 - 04:45 PM
is there a safety switch in the dash tower that the pto lever makes contact with?
  • middleageddeere said thank you
#7 GWest OFFLINE
GWest
  • 547 Thanks
  • 499 posts
Posted May 10, 2011 - 04:50 PM
Without a model number can't look at the wiring diagram.
Will guess if battery ignition it is powered by the seat switch with operator in the seat when the pto is on. Powered by the pto switch when pto is off.
If magneto ignition the seat switch should be open with operator in the seat and the pto on.
Likely the seat switch is your problem. It thinks you fell out of the seat with the mower going.
Garry
#8 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted May 10, 2011 - 05:16 PM
Yep, sound like safety switch to me too. Either under the seat or at the pto lever or a broken wire in between.
#9 caseguy OFFLINE
  • 1,628 Thanks
Posted May 10, 2011 - 07:07 PM
mecanical pto...Toatally cuts out
I think everyone's right about the seat switch. The two switches (PTO and seat) work in tandem so when you engage the PTO, it "looks" for the seat switch. If you take the model number and serial number to your local Toro dealer, they should have them on hand.
#10 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted May 10, 2011 - 07:08 PM
The model number is 21-08K801
#11 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted May 10, 2011 - 07:26 PM
I remember now because I replace the 308's fender pan on another tractor C-125 Auto had a better one to use with no paint flaking or rust . I need to put the old seat switch in this other fender pan .
#12 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted May 10, 2011 - 07:27 PM
I answered my own question but thank you for helping me everyone
#13 Texas Deere and Horse ONLINE
  • 14,814 Thanks
  • 15,502 posts
Posted May 10, 2011 - 08:06 PM
That should solve your problems...Good Luck and keep us posted.
#14 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted May 10, 2011 - 08:21 PM
I love it when a problem gets solved!
#15 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted May 12, 2011 - 11:19 PM
I put swaped seat switches around that was in the 308 not it works with the PTO engaged .
