Bought this neat little contraption at an auction the other day
23 replies to this topic
#16 MH81 OFFLINE
  • 29,978 Thanks
Posted June 08, 2016 - 11:46 AM
Sounds like an intake air leak. Check your gaskets and make sure carb base isn't bent.
  • Sawdust and Reed Breneman have said thanks
#17 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted June 08, 2016 - 04:42 PM
I like that & what a deal. Good find.
  • Reed Breneman said thank you
#18 jimmy G ONLINE
jimmy G
  • 1,295 Thanks
  • 826 posts
Posted June 09, 2016 - 01:12 AM
I'm thinking fuel pump issue, their is a one way valve on the pickup that sticks, the screens on the pickups have to be very clean, make sure the valve's on fuel pump are seating correctly, the spring and buffer cap can slip when installing the fuel pump,pickup tube's could be plugged (the long one is good for doing this).plan B,gravity feed carb.and strap on gas tank, would look more correct on an older rig to imo
  • MH81, Alc and Reed Breneman have said thanks
#19 Reed Breneman OFFLINE
Reed Breneman
  • 2,756 Thanks
  • 874 posts
Posted June 09, 2016 - 06:12 AM
I am gonna check a few little things,,,,like it came to me early(4 am) that I may not have installed the intake gasket (dont ask),It did start to run better the longer it ran but still had troubles and when it pops it has a 1 foot or better flame
#20 Reed Breneman OFFLINE
Reed Breneman
  • 2,756 Thanks
  • 874 posts
Posted June 09, 2016 - 06:14 AM
I also dont like where the muffler runs ,seems to heat up the carb real well
#21 KennyP ONLINE
  • 40,858 Thanks
  • 47,081 posts
Posted June 09, 2016 - 06:22 AM
Bet it heats up the gas tank real well too! Get a pipe street ell and put that into the block. If you get a 45°, you can turn it up and out some. Go by the electrical dept. and get a conduit lock nut for the threads into the block.
#22 Reed Breneman OFFLINE
Reed Breneman
  • 2,756 Thanks
  • 874 posts
Posted June 09, 2016 - 07:22 AM
Also heats up the operator real well to
#23 DougT OFFLINE
DougT
    Dog Approved
  • 7,110 Thanks
  • 5,075 posts
Posted June 09, 2016 - 08:44 AM
The original muffler for that was flat and had a deflector to send the exhaust sideways. I think it was a bolt on.
#24 GWest OFFLINE
GWest
  • 555 Thanks
  • 507 posts
Posted June 09, 2016 - 09:00 AM
Here is a parts list
https://www.partstre...s-list-3580i01/
Should be able to download the operator manual but can't get it to work
https://www.simplici...equested=990149
Garry
See the last link to a manual is working now.
Garry
