Sabre by John Deere
9 replies to this topic
#1 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 16, 2016 - 01:34 PM
Is this the correct forum? Or is there a hidden sub set I missed?
#2 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 16, 2016 - 02:29 PM
Yep..I think your in the right place!
#3 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 16, 2016 - 02:46 PM
Awesome! I have a sabre with the 18hp v-twin OHV Vanguard. It is not getting fuel. Already replaced the fuel pump am going to replace all lines later today hopefully. Is there anything else (compression) that I should take a look at first?
Edit: I CAN feel suction from the pump. Not sure what the levels need to by but there is some.
Edited by STEELRAIN13F, May 16, 2016 - 02:49 PM.
#4 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 16, 2016 - 02:52 PM
did you try priming the pump?I have gad to do that before..blow into the tank(with it 1/2 full)You can use your mouth..or a wet rag and a couple of quick puffs with compressed air...works best if you do it while cranking it over..I am sure you checked the fuel filter right?
  • boyscout862 and STEELRAIN13F have said thanks
#5 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 16, 2016 - 02:54 PM
Brand new filter. Haven't tried priming it. I'm replacing the lines either way as they are the original lines and the PO didn't take care of it.
  • Auburn David said thank you
#6 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 16, 2016 - 02:55 PM
If its getting to the carb and you still have issues it could be the needle and seat or the Eletric shut off valve on the bottom of the carb float bowl..be sure it has a good ground and is getting power(sometimes they stick..but you can unscrew it and clean it out)
  • Trav1s and old coot have said thanks
#7 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 16, 2016 - 02:57 PM
It's not getting to the carb. It wasn't even getting to the filter. I know that where the line goes into the tank wasn't sealed so that may be the issue.
#8 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 16, 2016 - 03:00 PM
this one is on a Kholer but works the same way..
#9 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted May 16, 2016 - 03:01 PM
and this is the bypass for a B&S https://www.youtube....Qw2pQ_oa6o#t=42
#10 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 16, 2016 - 03:03 PM
I will pull it off and give it a look. Thank you. I'll post results.
