Rebuild/Replace Smoky OH140 Tecumseh?
19 replies to this topic
#16 Bolens 1000 ONLINE
  • 15,565 Thanks
  • 18,321 posts
Posted May 22, 2016 - 03:56 PM
 The bore for a OH140 is the same as the HH100.
Without pulling the parts list , are you sure that is right? How can the bores be the same when one is 14HP and the other is 10HP?
  • Paulgo said thank you
#17 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted May 22, 2016 - 04:15 PM
They both have a 3 3/8th" bore.
#18 DH1 ONLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted May 22, 2016 - 04:47 PM
Bore and stroke are the same for HH100 and OH140
HH100 is flat head =10hp
OH140 is overhead valve = 14hp
#19 MFDAC ONLINE
MFDAC
  • 3,649 Thanks
  • 1,739 posts
Posted May 22, 2016 - 07:26 PM
Usually a tapered bore us bigger at the top of the cylinder.
It could be but I have always seen wear taper at the lower part of the cylinder, never at the top. Just ring wear at the top, causing the need to ream the ridge sometimes. The sideways thrust from the connecting rod angle causes the piston to be pushed sideways for a bit at the bottom until the rod straightens out towards the top of the bore going up to TDC. At TDC the rod is straight with the bore. Just my experience from working with race engines back in the day, and choosing used blocks for the machining.
DAC
#20 TAHOE ONLINE
TAHOE
  • 8,339 Thanks
  • 5,820 posts
Posted May 23, 2016 - 07:07 AM
guess I missed that one.....
