Rebuild/Replace Smoky OH140 Tecumseh?
19 replies to this topic
#1 Paulgo ONLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted May 16, 2016 - 12:30 PM
This OH140 engine is on an old Bolens that my neighbor owns. Tractor is still being worked, but uses oil and puts out a lot of smoke. He'd like to have engine rebuilt or replaced with good used horizontalal shaft engine. I don't see any actual rebuild kits online for it. Will probably just have to see what other engines turn up in our area and try to match stub shaft and electric clutch?
Paul
Edited by Paulgo, May 16, 2016 - 12:48 PM.
  • debbieox4 said thank you
#2 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted May 16, 2016 - 01:13 PM
Depending on how worn your bore is you could very well be ok just re-ringing the motor if all its doing is smoking and still has power.
I have fixed many wisconsins with similar issues just doing the valves and rings
  • boyscout862, Auburn David, Bolens800uk and 1 other said thanks
#3 boyscout862 ONLINE
  • 12,529 Thanks
  • 9,032 posts
Posted May 16, 2016 - 03:51 PM
For the heck of it, try putting 1/2 oz of Marvel Mystery Oil in each gallon of gas that it gets. The Marvel may free up the rings and reduce smoking. It takes awhile but has worked well on many engines for me over the passed 49 years. Good Luck, Rick
  • Sawdust, propane1 and Paulgo have said thanks
#4 KennyP ONLINE
  • 37,412 Thanks
  • 45,460 posts
Posted May 16, 2016 - 04:11 PM
I'll second that! Worked for me a few times! Put an ounce or so in the oil too!
  • boyscout862, propane1 and Paulgo have said thanks
#5 propane1 ONLINE
propane1
  • 8,445 Thanks
  • 4,029 posts
Posted May 16, 2016 - 05:01 PM
Helped some of my engines to, but I use transmission fluid, in the gas and oil. Governor was stuck in my 1951 tea20 ferguson farm tractor. The transmission fluid fixed it. Governor works now.
Noel
  • Paulgo said thank you
#6 Paulgo ONLINE
Paulgo
  • 689 Thanks
  • 461 posts
Posted May 16, 2016 - 05:43 PM
I wonder if soaking over night with atf and then draining/refilling with normal oil might free up stuck rings?
I have limited experience inside an engine and a couple of stupid questions. 1. If the bore isn't too bad I might be able to re-ring the piston. Would that be with the same size or the next size wider rings? 2. Doing the valves? Is that just lapping and adjusting or would it involve seats and guides?
#7 boyscout862 ONLINE
  • 12,529 Thanks
  • 9,032 posts
Posted May 16, 2016 - 07:15 PM
Try pouring an ounce of MMO through the plug hole when the piston is down abit and let it sit for a few days. For overhauling, You can go to the length you want. When I do a "swamp yankee refresh job" on a cheap old engine I: disassemble and clean the engine, inspect all wear surfaces, ridge ream and hone the cylinder(if it is less than 0.008" over I reuse the piston and rings), clean the piston and ring groves, clean each ring and then rub with croacous cloth lengthwise, clean and lap the valves, grind the valve lash to 0.002" less than is called for(this allows latter correction), assemble with new gaskets and seals, overhaul the carb and clean the tank, fill fluids, run for 15 to 30 minutes and change the oil. I've gained many years this way without spending more than the $20 for the gasket set.  Find a freebie lawn mower to practice on first. The B&S Repairmans' Manual(jn our Manuals Section) is excellant.  Good Luck, Rick
Edited by boyscout862, May 16, 2016 - 07:19 PM.
  • Sawdust and Paulgo have said thanks
#8 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted May 16, 2016 - 07:37 PM
In most cases the same size ring set, I would also hone the cylinder when installing the new rings as well as lapping the valves. All of this can be done fairly easy with inexpensive tools
  • MH81 and Paulgo have said thanks
#9 MFDAC OFFLINE
MFDAC
  • 3,152 Thanks
  • 1,568 posts
Posted May 16, 2016 - 09:19 PM
Most of the time these ideas work but in my case with an HH120 the cylinder had enough "taper" (wider at the bottom of the bore) that the piston was actually cocked a few thousanths. Overbore pistons are rare and expensive. It still ran great but it was getting hard to see through the smoke. I re-powered it with a new Honda clone. This pic is the top ring land that shows the piston was riding crooked in the bore. I tried a standard bore rebuild but it didn't last long.
DAC
Edited by MFDAC, May 16, 2016 - 09:33 PM.
  • boyscout862, dodge trucker and Paulgo have said thanks
#10 ClassicBolens OFFLINE
ClassicBolens
  • 1,375 Thanks
  • 495 posts
Posted May 17, 2016 - 09:35 PM
If you go with new rings, I also recommend replacing the valve guides while you're in there. They are typically prone to wear before the valve stems do (I'd check the valves for wear too). Worn guides can cause a lot of smoke and oil bypassing. Tecumseh Part# 730218. They run less than $20.00.
#11 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted May 19, 2016 - 08:07 AM
Yeah, could be a valve guide issue. Heads can be a pain to remove, I've done the one on my OH160, you have to remove all the springs/keepers to be able to remove the upper rocker box so you can access a couple head bolts.
The 14 has a different bore than the others so good luck finding rings, those were as plentiful as the 12's or 16's
#12 det12187 OFFLINE
det12187
  • 44 Thanks
  • 59 posts
Posted May 19, 2016 - 10:32 AM
With the expense of machining and parts I would go with re-powering with a Honda clone.
Overhead valve, quiet, and fuel effcient.
#13 dodge trucker ONLINE
dodge trucker
  • 2,297 Thanks
  • 3,014 posts
Posted May 21, 2016 - 06:46 PM
Honda no way.
#14 dodge trucker ONLINE
dodge trucker
  • 2,297 Thanks
  • 3,014 posts
Posted May 22, 2016 - 01:10 PM
DAC
Usually a tapered bore us bigger at the top of the cylinder.
  • MFDAC and Paulgo have said thanks
#15 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted May 22, 2016 - 02:37 PM
 The bore for a OH140 is the same as the HH100.
  • TAHOE and Paulgo have said thanks
