Identify name and use of a pair of pins found in toolbox of mw gilson
6 replies to this topic
#1 ktznz OFFLINE
ktznz
  • 64 Thanks
  • 90 posts
Posted May 15, 2016 - 03:26 PM
Found a pair of "pins" with sliding rod at one end. The dimensions are 1" diameter and tapered end and the total length of pin is 2 1/4" long. What is the name and what are they used for. Thanks.mw_1inch_dia_by_2.25inch_pin.JPG
  • juliannegu3 said thank you
#2 IamSherwood OFFLINE
  • 8,390 Thanks
Posted May 15, 2016 - 03:42 PM
After looking at the pic for 5 or 6 minutes, I was about to
give up.
I had no idea what they're for.
BUT, then I went back to you're original post and figured it out!
They're for your mw Gilson.
  • wvbuzzmaster, KennyP, boyscout862 and 1 other said thanks
#3 wvbuzzmaster OFFLINE
  • 4,714 Thanks
Posted May 15, 2016 - 04:01 PM
Will is correct, they mount front implements like mule drives to the front of the frame on a Gilson tractor.
  • IamSherwood, boyscout862 and ktznz have said thanks
#4 EricFromPa ONLINE
EricFromPa
  • 3,226 Thanks
  • 2,910 posts
Posted May 15, 2016 - 04:03 PM
Looks like the Pins that hold the plow or snow blower on the front.Put it in the hole and push the small pin into the square keeper.
Here found a couple pics.
I was missing one of those on my old monkey so I took an old Chinese deep well socket and drilled a hole in it jammed it in the hole and wired it fast.
Edited by EricFromPa, May 15, 2016 - 04:09 PM.
  • Alc, wvbuzzmaster, IamSherwood and 4 others have said thanks
#5 KC9KAS OFFLINE
KC9KAS
  • 5,203 Thanks
  • 4,587 posts
Posted May 15, 2016 - 06:45 PM
Darn, I knew exactly what those were, as I just took 2 off of my wife's Gilson!
#6 ktznz OFFLINE
ktznz
  • 64 Thanks
  • 90 posts
Posted May 15, 2016 - 07:55 PM
Thanks to KC9KAS,  Casey, IamSherwood and EricFromPa(Thanks for the pics).
I just picked up a tiller with side skirts and the PTO mule. Never would have been able to attach it without those pins, unless I had found them or found EricFromPa solution. Great!! That means I also found an  older set of pins for the tiller connection as well as one of the original wear plates for the tiller. My day is made! ken
  • wvbuzzmaster, IamSherwood and EricFromPa have said thanks
#7 Sprint 6 OFFLINE
Sprint 6
  • 209 Thanks
  • 268 posts
Posted May 16, 2016 - 06:04 PM
They are referred to as trunion pins in the manual.  The tiller PTO, dozer blade frame, generator, etc. mount from them.
  • ktznz said thank you
