electric pto?
6 replies to this topic
#1 dszymo1 OFFLINE
dszymo1
  • 1 Thanks
  • 2 posts
Posted May 15, 2016 - 11:28 AM
if you switch the wires around at the plug on pto of a power king will it affect the tractor at all?  the reason I'm asking is because I put the mower deck back on and the post on the back of the ignition switch is starting to get hot and melt.
  • Auburn David said thank you
  • 14,889 Thanks
  • 15,514 posts
Posted May 15, 2016 - 11:35 AM
Welcome to GTtalk. I would think that its corrosion on the connection on the switch or a bad ground.
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 15, 2016 - 12:19 PM
It can if the PTO has a grounded case..it will be a dead short.
#4 boyscout862 ONLINE
  • 13,557 Thanks
  • 9,431 posts
Posted May 15, 2016 - 12:46 PM
Welcome to GTT. You can download the manual from our Manuals Section and check the wiring diagram. Good Luck, Rick
#5 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted May 15, 2016 - 02:23 PM
:welcometogttalk:
I have to agree with Auburn David. Get a good volt/ohm meter ad disconnect the wires to the electric clutch.
Test for continuity from each wire to ground. If you show continuity on a wire, that wire CAN NOT be attached to + Positive/Power.
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted May 15, 2016 - 06:44 PM
Some PTO's have an internal diode that will present a dead short if hooked up backwards.
#7 dszymo1 OFFLINE
dszymo1
  • 1 Thanks
  • 2 posts
Posted May 16, 2016 - 03:04 PM
ok I will try that thanks
