Pump problems
5 replies to this topic
#1 tractor buddy OFFLINE
tractor buddy
  • 3 Thanks
  • 56 posts
Posted May 10, 2011 - 09:32 AM
I have a non factory FEL york john...something. When I hit the lever the lift shutters and stops. The belt stops spining and the pump stops. I am looking for a new link belt (any one have info) do I need a new pump also ?
#2 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 10, 2011 - 10:03 AM
I have seen those belts at Tractor Supply.
I keep one around just to size belts.
Pump should be OK.
Look at the pulleys and make sure they are not wore so the belt can not get traction.
  • tractor buddy said thank you
#3 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted May 10, 2011 - 10:32 AM
I am not real good with hydraulics but possibly a relief valve isn't working correctly?
#4 tractor buddy OFFLINE
tractor buddy
  • 3 Thanks
  • 56 posts
Posted May 10, 2011 - 11:28 AM
would anyone know if the pulley between the engine and trans on a 69 PK (still not sure of model #) is 5/8 "
Edited by tractor buddy, May 10, 2011 - 12:27 PM.
#5 Alc ONLINE
  • 6,912 Thanks
  • 7,472 posts
Posted May 10, 2011 - 08:25 PM
Pretty sure they are 1/2" wide
#6 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted May 10, 2011 - 08:33 PM
I am pretty sure we are looking at a slip issue.
Belt wore/Pulley wear?
If pump was an issue you should see belts smoking and a heavy load on the engine.
With out a heavy load on the engine and pump stops turning you for sure have a drive problem. (Belt/Pulley)
