Frankentractor?
29 replies to this topic
#16 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 12:07 PM
Awesome, thank you. Fun part is now I know I don't have original motor or trans. This'll be fun. Motor so far seems strong. Only issue this far is it won't move. Like I stated before I have no clue about hydrostatic trannys. I'll get a pic of its factory stamp.
#17 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 12:10 PM
751-047 CW 013192
Edited by STEELRAIN13F, May 15, 2016 - 12:11 PM.
  • blackjackjakexxix and MailmAn have said thanks
#18 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted May 15, 2016 - 12:41 PM
That's an Eaton 7 hydro. What it came out of could be anyone's guess. They were commonly used on just about every brand you can think of. Bolens used the Eaton 7 on their later model lawn tractors such as the H11LT (1011H) and the ST series such as the ST140 (3014H).
Sorry, I didn't see your last post with the transaxle numbers. I was looking at the orientation of your other trans pictures wrong and didn't realize the picture was sideways which lead me to think it was the Eaton 7, which is incorrect.
The Eaton 750 - 751 was a light duty hydrostatic transaxle. They were used in a variety of small lawn tractors, including some later Bolens ST series. These were considered a "non tilling" type trans and were not recommended for any real heavy pushing or pulling.
Edited by ClassicBolens, May 15, 2016 - 01:12 PM.
  • LPBolens, Bruce Dorsi, IamSherwood and 2 others have said thanks
#19 Toolfoole OFFLINE
Toolfoole
  • 271 Thanks
  • 145 posts
Posted May 15, 2016 - 12:52 PM
You beat me to it, ClassicBolens. I found the info in the 1987 Equipment Seminar book on pp 28, 29 (pdf pp 30, 31). It looks as though the LT11 was first offered in 1979 (1113-01), as you stated, but it was in production for 4 years ending in 1982. In 1980 the model designation became 1113-02. The correct 11hp B&S engine was Model No. 252707-018901 for the entire run.
#20 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 12:59 PM
Any idea as to what my drive belt size would be?
#21 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted May 15, 2016 - 01:18 PM
Not a clue. With it being customized to fit the hydro trans I doubt they used the original belt for the 3 speed trans. If you're lucky, there may be a number on the belt. If not, you'll likely have to take it with you to get it matched up.
#22 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 01:50 PM
Sounds good. Hopefully I can get it sorted quickly. The current belt will rotate the fins on the hydro but it won't move. So not sure what exactly the issue is.
#23 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted May 15, 2016 - 02:20 PM
It looks like most of the fins on your cooling fan are broken off, but maybe it is just the picture. If that is the case you will want to replace or repair it. I haven't got much experience with hydro transaxles either, but I do know some of them have a lever that allows them to free-wheel. If the  lever is in that position it won't move.
Jim
  • ClassicBolens said thank you
#24 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 02:32 PM
Now to locate the lever lol. Thank you for the help. I would be up a creek without it.
#25 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 15, 2016 - 02:52 PM
If hose has been leaking, fix that and maybe just needs refill???  ON pressure release, may just be a button that will pop back out when running, or some even had bolt heads to turn or loosen, like on Wheelhorse brands.  Think you'll need a manual for whatever axle you have in it also to make sure all the items are correct enough to run it.  Check for weather the axles might be turning IN the wheels centers. Sometimes there are keys or such that shear off and can't drive the wheel anymore.
  • Bmerf and STEELRAIN13F have said thanks
#26 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 03:35 PM
Hose replaced and refilled. Still no luck. Really hope it's not shot. That would give me two shot gt's.
Edited by STEELRAIN13F, May 15, 2016 - 03:36 PM.
#27 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 04:04 PM
In case anyone needed the eaton 751-750-781 manual here it is.Attached File  pll_1620.pdf   935.57KB   147 downloads
Edited by STEELRAIN13F, May 15, 2016 - 04:05 PM.
  • Bruce Dorsi and Paulgo have said thanks
#28 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 15, 2016 - 04:37 PM
How do I go about finding the original transmission number. I'm thinking that may be my best option.
#29 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted May 16, 2016 - 01:00 PM
I lifted the rear of the gt and wheels will move, albeit slowly. So I'm leaning toward the belt being too lose or it's a pulley causing it to jump off track. Any thoughts?
Edited by STEELRAIN13F, May 16, 2016 - 01:01 PM.
#30 STEELRAIN13F OFFLINE
STEELRAIN13F
  • 33 Thanks
  • 56 posts
Posted June 29, 2016 - 12:20 AM
I've been tinkering with this a bit more. Unfortunately, no progress has been made. Any help would be appreciated.
  • HJR said thank you
